Re: Puch maxi crossover build: swing arm question
It’s was actually a super easy fix...all I did was cut the slugs off the old moped, dremeled the pedal shaft on the puch and hammered the slugs in. Going to need a few washers a make sure everything is perfect but that’s how I roll.
  Puch maxi crossover build: swing arm questionTopic by: * * * * 01/17/19 07:30PM
  Re: Puch maxi crossover build: swing arm questionRe: P D P D 01/18/19 08:52AM
  Re: Puch maxi crossover build: swing arm questionRe: Probably Fred Probably Fred 01/18/19 10:30AM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/18/19 01:38PM
  Re: Puch maxi crossover build: swing arm questionRe: P D P D 01/18/19 01:58PM
  Re: Puch maxi crossover build: swing arm questionRe: Probably Fred Probably Fred 01/18/19 04:23PM
  Re: Puch maxi crossover build: swing arm questionRe: Seth B Seth B 01/18/19 06:42PM
  Re: Puch maxi crossover build: swing arm questionRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 01/18/19 02:43PM
  Re: Puch maxi crossover build: swing arm questionRe: Mr. Duncan Mr. Duncan 01/18/19 03:25PM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/18/19 05:16PM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/18/19 07:19PM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/18/19 08:31PM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/19/19 04:33PM
  Re: Puch maxi crossover build: swing arm questionRe: Daniel '' Daniel '' 01/19/19 07:36PM
  Re: Puch maxi crossover build: swing arm questionRe: P D P D 01/19/19 07:48PM
  Re: Puch maxi crossover build: swing arm questionRe: Daniel '' Daniel '' 01/19/19 09:58PM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/19/19 10:44PM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/19/19 10:51PM
  Re: Puch maxi crossover build: swing arm questionRe: P D P D 01/20/19 09:46AM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/20/19 01:52PM
  Re: Puch maxi crossover build: swing arm questionRe: kevin Smellaflange kevin Smellaflange 01/22/19 05:02PM
  Re: Puch maxi crossover build: swing arm questionRe: * * * * 01/22/19 07:21PM
