Re: Tomos rear wheel spin/slowdown issue
Simon Belmont /
Okay, I've replaced both bearings inside the wheel but they weren't the issue, I narrowed it down to brakes, when detaching the brake cable, the wheel spins fine, but as soon as brake cable is added and adjusted to proper tension, that's when the wheel does this (spins fine half-way then drags a bit then spins fine again) so I'm guessing the internal hub is probably out of round.
