Re: Tomos rear wheel spin/slowdown issue
cheetahchrome . /
I go through this a lot. This always helps. Loosen both axle nuts. next apply the brake lever and hold it tight. I use tape around the lever and hand grip. Then tighten the two axle nuts as you normally would. Release the brake lever and check the spin of the wheel.
