Re: ??? Tomos help
Marc Friedman /
So most common no sparkie state of a Sprint is a defective hall sensor. Find the wiring diagram and identify the two wires of the hall sensor( it's the timer for the cdi and is energized with each rotation of the flywheel. ) You will find if both leads are hooked to a multimeter whether or not a ac current is generated. That's where I would start. There have been numerous posts on this if you do a search.
