Re: Intalling an offset Intake Manifold for tomos A5
jonny 5ive /
You have a Dellorto SHA carb, size 14.12 (mm) which should be notated on the side. When he said 15.15 he means the size. He upgraded to a Dellorto SHA 15.15 along with the aftermarket MLM brand intake to match the carbs 15mm size.
When you bought this did the carb have the stock round metal screen filter that fits into the carb, with a separate small plastic dome cover? That's what those 2 people are suggesting would fit in this scenario but I'm assuming yours was bare when bought or you would have tried it. The metal mesh stock filter has several layers that you can pry out one by one for more air flow.
You can also thug it out for more air flow and use a ziptie and pantyhose to cover the carb as a "filter". Although with all that air coming in you would need to rejet the carb to a bigger jet to match your air/fuel mix so you don't run lean.
The majority of people find all the parts they need using https://www.treatland.tv and https://www.doscycles.com
  Intalling an offset Intake Manifold for tomos A5Topic by: Charles Fowler Charles Fowler 01/13/19 12:25PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Saabsonettguy . Saabsonettguy . 01/13/19 12:54PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Saabsonettguy . Saabsonettguy . 01/13/19 12:59PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Charles Fowler Charles Fowler 01/13/19 04:51PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/14/19 09:20AM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Charles Fowler Charles Fowler 01/14/19 02:23PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Charles Fowler Charles Fowler 01/14/19 02:26PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Charles Fowler Charles Fowler 01/13/19 01:37PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Lilou Vinson Lilou Vinson 01/14/19 07:20AM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Saabsonettguy . Saabsonettguy . 01/14/19 08:32AM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Tyler Hautau Tyler Hautau 01/14/19 08:36AM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Mike Fitzgerald Mike Fitzgerald 01/14/19 12:08PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: pat splat pat splat 01/14/19 08:27PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: Charles Fowler Charles Fowler 01/15/19 03:31PM
  Re: Intalling an offset Intake Manifold for tomos A5Re: jonny 5ive jonny 5ive 01/14/19 09:38PM
