1970 Puch MS50D starts ok , does`nt want to change gear smoothly.
Kevin Gatward /
Hi, my 1970 Puch MS50D starts ok, but wont change gear smoothly. tried adjusting the 3 speed cables, makes no difference. I was thinking of taking the clutch to bits. any thoughts. Kevin
Re: 1970 Puch MS50D starts ok , does`nt want to change gear smoothly.
Tri-ped Dave O.D.B. /
Make sure your clutch cable casing is not stretched out causing it to not fully disengage before you take it apart. Adjust your cables including the shift cables making sure both are tight when the indicator reads neutral, and that when so it is actually in the center of neutral
Probably Fred /
Pretty sure it’s a 2 speed not a 3 speed
