Re: access to my drum brakes in rear hub?
Bas Autowas /
Mopeds are so insanely simple to work on and the best attitude is to just tear into parts and see what happens. I knew nothing about mopeds when i was 15 and now through trial and error i can do most work with my eyes closed.
There were no tutorials online back then but a service manual (which i bet there is for your tomos) and just doing it will get you a long way.
If you need 4 more topics to replace the springs in your brake, mopeds might not be for you. (edited)
  access to my drum brakes in rear hub?Topic by: thad wingfield thad wingfield 01/08/19 02:31PM
  Re: access to my drum brakes in rear hub?Re: pat splat pat splat 01/08/19 02:35PM
  Re: access to my drum brakes in rear hub?Re: thad wingfield thad wingfield 01/08/19 02:57PM
  Re: access to my drum brakes in rear hub?Re: pat splat pat splat 01/08/19 03:52PM
  Re: access to my drum brakes in rear hub?Re: Dirty30 Dillon Dirty30 Dillon 01/08/19 03:59PM
  Re: access to my drum brakes in rear hub?Re: thad wingfield thad wingfield 01/08/19 04:12PM
  Re: access to my drum brakes in rear hub?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/08/19 04:20PM
  Re: access to my drum brakes in rear hub?Re: ID OD ID OD 01/08/19 04:23PM
  Re: access to my drum brakes in rear hub?Re: thad wingfield thad wingfield 01/08/19 04:26PM
  Re: access to my drum brakes in rear hub?Re: Dirty30 Dillon Dirty30 Dillon 01/08/19 04:35PM
  Re: access to my drum brakes in rear hub?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/08/19 04:46PM
  Re: access to my drum brakes in rear hub?Re: thad wingfield thad wingfield 01/08/19 05:21PM
  Re: access to my drum brakes in rear hub?Re: Bas Autowas Bas Autowas 01/08/19 05:28PM
  Re: access to my drum brakes in rear hub?Re: Mike Boyd Mike Boyd 01/08/19 05:46PM
  Re: access to my drum brakes in rear hub?Re: ID OD ID OD 01/08/19 07:29PM
  Re: access to my drum brakes in rear hub?Re: P D P D 01/08/19 07:21PM
  Re: access to my drum brakes in rear hub?Re: Mike Boyd Mike Boyd 01/08/19 04:27PM
  Re: access to my drum brakes in rear hub?Re: pat splat pat splat 01/08/19 06:06PM
  Re: access to my drum brakes in rear hub?Re: thad wingfield thad wingfield 01/08/19 06:22PM
