Re: Sachs prima backfiring out the intake!
Born to be WillD /
If you broke a ring I wouldn't be surprised if it gouged the cylinder too. then you would still have poor compression and that'd cause the problems you're having
https://www.mopedarmy.com/wiki/Sachs_505/1a_performance
lotta detail in that page including plugging the decomp. bad decomp could cause the mentioned issues too.
Timing i'd agree though is most likely. you should be able to adjust through the windows in the flywheel.
do you have a 20mm Mik on a stock 50cc? I used to have an 18 on my sachs (I didn't set it up that way) you'd definitely be better off with a smaller carb on a stock jug. or go ham porting it up
  Sachs prima backfiring out the intake!Topic by: Eli Stuart Eli Stuart 01/07/19 10:47PM
  Re: Sachs prima backfiring out the intake!Re: Ademir Cruz Ademir Cruz 01/08/19 12:02AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 05:53AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 01:49PM
  Re: Sachs prima backfiring out the intake!Re: Kim Jong illest Kim Jong illest 01/08/19 04:57AM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/08/19 07:02AM
  Re: Sachs prima backfiring out the intake!Re: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/19 07:24AM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/08/19 11:04AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 11:47AM
  Re: Sachs prima backfiring out the intake!Re: pat splat pat splat 01/08/19 02:33PM
  Re: Sachs prima backfiring out the intake!Re: Born to be WillD Born to be WillD 01/08/19 03:18PM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/09/19 05:56AM
  Re: Sachs prima backfiring out the intake!Re: Chöschi21 C.K. Chöschi21 C.K. 01/09/19 06:11AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/09/19 12:00PM
  Re: Sachs prima backfiring out the intake!Re: Chöschi21 C.K. Chöschi21 C.K. 01/09/19 02:22PM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/09/19 04:59PM
