Re: Sachs prima backfiring out the intake!
pat splat /
alotta times i just bump it with an impact just to break it. is all above checks out then, clean grounds under side cover, upjet cuz 60 in a 20 mm carb is small, and delete decomp,theres a wiki on it if it hasnt been done.
  Sachs prima backfiring out the intake!Topic by: Eli Stuart Eli Stuart 01/07/19 10:47PM
  Re: Sachs prima backfiring out the intake!Re: Ademir Cruz Ademir Cruz 01/08/19 12:02AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 05:53AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 01:49PM
  Re: Sachs prima backfiring out the intake!Re: ***Kim Jong illest*** ***Kim Jong illest*** 01/08/19 04:57AM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/08/19 07:02AM
  Re: Sachs prima backfiring out the intake!Re: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/19 07:24AM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/08/19 11:04AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 11:47AM
  Re: Sachs prima backfiring out the intake!Re: pat splat pat splat 01/08/19 02:33PM
  Re: Sachs prima backfiring out the intake!Re: Born to be WillD Born to be WillD 01/08/19 03:18PM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/09/19 05:56AM
  Re: Sachs prima backfiring out the intake!Re: Chöschi21 C.K. Chöschi21 C.K. 01/09/19 06:11AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/09/19 12:00PM
  Re: Sachs prima backfiring out the intake!Re: Chöschi21 C.K. Chöschi21 C.K. 01/09/19 02:22PM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/09/19 04:59PM
