Sachs prima backfiring out the intake!
Eli Stuart /
Traded my honda a couple weeks ago for a sachs. It wasn't running at first but then I cleaned the carb and it ran ok-ish. It would idle and rev up a little bit back and forth and have zero power going downhill. I took off the jug and whatayaknow it only had one compression ring instead of two lol. Ordered a new ring and put it on but it will continue to backfire out the carb if you go down a hill. Idk what's up thanks
  Sachs prima backfiring out the intake!Topic by: Eli Stuart Eli Stuart 01/07/19 10:47PM
  Re: Sachs prima backfiring out the intake!Re: Ademir Cruz Ademir Cruz 01/08/19 12:02AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 05:53AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 01:49PM
  Re: Sachs prima backfiring out the intake!Re: ***Kim Jong illest*** ***Kim Jong illest*** 01/08/19 04:57AM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/08/19 07:02AM
  Re: Sachs prima backfiring out the intake!Re: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/19 07:24AM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/08/19 11:04AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/08/19 11:47AM
  Re: Sachs prima backfiring out the intake!Re: pat splat pat splat 01/08/19 02:33PM
  Re: Sachs prima backfiring out the intake!Re: Born to be WillD Born to be WillD 01/08/19 03:18PM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/09/19 05:56AM
  Re: Sachs prima backfiring out the intake!Re: Chöschi21 C.K. Chöschi21 C.K. 01/09/19 06:11AM
  Re: Sachs prima backfiring out the intake!Re: Eli Stuart Eli Stuart 01/09/19 12:00PM
  Re: Sachs prima backfiring out the intake!Re: Chöschi21 C.K. Chöschi21 C.K. 01/09/19 02:22PM
  Re: Sachs prima backfiring out the intake!Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/09/19 04:59PM
