helpful tools
I got an amazon gift card for Christmas and was going to use it to get some tools for working on my bikes. I already added a 3/8 torque wrench I'm looking for a cheap but good mechanics stool, an impact screwdriver (not electric), a different petcock than the leaky stock ones I have. and front and rear tire bearings. I have enough socket wrenches and regular tools
Re: helpful tools
Shawn Skibicki /
Bearing pullers, easy outs, chain breaker, multi meter, a quality pair of C clip pliers, scraper, hole punch set (if you are cutting your own gaskets), a stud remover/installer, flywheel pullers.
Re: helpful tools
Tire spoons/levers.
Dremel.
Telescoping magnet.
Adjustable gap spark tester.
Inner tube valve removal tool.
Re: helpful tools
♣Slew Foot♣ /
Flywheel puller for your bike.
Brass or copper hammer.
Re: helpful tools
Ok thanks guys is there a specific bearing puller I should look for? That’s the first thing I’m going to be working on
Re: helpful tools
Timing strobe light.
Re: helpful tools
TOP GUN™ ANDY ⚔ (LSLB) ⚔ /
Ignition micrometer
JIS bits (if you do hobbits)
Vacuum tester (the best way to check for airleaks)
Hole punches
Don't forget shop niceties! Get some hand soap, shop towels, gloves, etc. Sometimes the QOL stuff you can forget about but it really makes a difference
Re: helpful tools
A breaker bar to match your sockets is a good idea.
Re: helpful tools
Keep a big ol pipe around for bending pedal arms.
Re: helpful tools
And , fitting over that breaker bar , for that sometimes needed extra oomph . ;)
Re: helpful tools
> oomph . ;)
^^like changing trailer hitch balls!
Or torquing moped head nuts;)
Re: helpful tools
Specially that last one . LOL
