Benelli build Tourismo Time
just gonna get her running and post
progress.
Re: Benelli build Tourismo Time
thanks john from st. louis and thanks for keeping the loose parts mostly together. only part i had to fab so far is a clutch release rod. it sits behind this rod. just cut a hf phillips screwdriver to fit.
check out this hi per case
opened up intake a bit.
gonna mess w the cylinder exhaust a bit, hope i dont f up
og carb is a del 14:9 , thats gotta open up.
Whoa, that case looks hella restricted. Following
Dirty30 Dillon /
Good ole fashioned moffa-style.
bigger and squarer, why not, slide is square.
not sure if this goes here, blow back pick up tube.
one more, more flow , honkin exhaust port measusures 100mm
Dirty30 Dillon /
That carb took a good walloping.
Isnt that the emulsion tube?
stock pipe w nut, this small header gotta go, hmmm. big muff??
lets see.
whoa almost perfect.
it sure is. i was kidding.
That 'new' header is almost as big as the piston .
Not sure it would allow enough flow ... LOL
damn, cool bike. v interested
Sorry about the clutch rod, pat. I looked everywhere. Cant wait to see the final product. Good stuff
dang! 2020 and finally got the big muff together. hoping to fire her up Today! anyone know what kinda tranny fluid for a shifty? kinda lost on this one.
Pushrod Fifty /
SAE30 oil.
I’d go for something like 20/50. Straight weight oil tends to get too thin when it heats up.
If that has a wet clutch , I'd use 15w40 diesel oil .
Works real well in my FA50 and Yamaha XT350 .
A lot of guys like it in the big Honda bikes .
I use Rotella T 15w40 in every bike I have, 2 or 4 stroke. Works great and its super cheap.
cant wait to see it running
make sure to post vids asap
Dirty30 Dillon /
Typically they called for SAE20 or SAE30.
If you haven't replaced the seals with modern seals, I would follow that. Some of the additives in modern synthetics can swell the old seals, which works fine for a bit but can fail.
The Benelli lives! Thanks for the oil recommendations, had to drain the atf i put in.
Still need to tune but my gut told me i should to learn to shift and stop first. I admit it, my brain from thinking, left hand from clutch pulling and right toe from downshifting kinda hurts, wahh wahh.
ive down jetted from 70 to 65 to 62, head temp still wont break 300. Just barely getting into the pipe, maybe i cut it too short for the big header not sure but i think itll be fine when the temps go up. Cruises at 35 in 3rd.
Odd thing, when in neutral u can kick start without it being in gear, dont have to pull clutch or nuthin, strange to my brain or maybe it just like any other tomos.
Worked on hetting electrics together, kill/lights, all on one master switch on headlight.
sorry no vdos.
Dirty30 Dillon /
Just like most motos, really. Just a reminder to go easy on the kicker. Lotsa people kick these small shifters over like they're cranking a panhead. You snap that little shaft and you'll be sad times.
Glad the bike's running tho
Emil Kniemel /
Those pedals work? Are you able to register it as a moped in CA?
