> Graham Motzing Wrote:
> > Thomas Davis Wrote:
> > Take an old cub add a bunch of emissions hoses, wiring, fuel
> injection,
> > and relays and an ecu that is likely to go out and you have a new
> super
> > cub.
> > I prefer the old version with stone reliability. I would say honda had
> > to submit to the times and install all the crap due to emissions, but
> > then you see that they added even more crap in the form of wireless
> > unlocking and such.
> Really? Like all those groms you hear about with 'ECU's going out'
> These things will be rock solid. The grom motor is pretty seriously
> dialed in. When has anyone had to 'Clean an EFI' system... i have a '99
> subaru in my driveway right now that has sat for the last 3 years under
> a tree, fixed the spark plug wire and fired up first kick. The fuel
> systems are sealed and made of ethanol compliant materials.
> I think ultimately at the 3500-5k price point, electrics will be taking
> over very soon but its nice to see honda putting some effort behind what
> will probably be the last iteration of this venerable design.
I had an ECU, and Fuel Pump go out on an 07 Metropolitan...the electric stuff will never be as reliable and easy to fix like to old stuff, the tradeoff is the engine may see a little more raw gas than with injection therefore the engine may wear out sooner.
No more cleaning the tank and carb, and filing the points after sitting in a garage 20 years, the new ones would be an expensive cluster fuck compared to the old stuff.
