Re: Gas and Oil
live ɘvil /
> Don Ohio Wrote:
> > Don Ohio Wrote:
> > YOUR LOSS, Dillon………..LOL! Capitals,mine.
> Here's an excerpt from a post on here on HOW to remove ethanol from
> gasoline. This was written on 11-1-2006:
> ` NOTE: There IS a way to remove the Ethanol from gasoline,but it takes
> care and you waste a little gas doing it.
> (1)If the gas is only 10-15% ethanol or less, you take a clean,CLEAR
> jug(so you can see thru it), and put water in..... about one-fifth of
> the jug's volume.This will absorb the alcohol in the gas.
> (2)THEN fill the jug with gas and you will actually see the reaction of
> the alcohol LEAVING the gasoline to become part of the water on the
> bottom.
> (3) The IMPORTANT thing to do next after 10 minutes have elapsed or
> more, is to pour off the pure gasoline that is above the layer of
> water/alcohol mix on the bottom of the jug.
> (4)You MUST NOT pour ANY of the solution from the bottom layer into the
> tank.
> (5) NOW you have pure gasoline with onlky a residue of alcohol
> remaining.
> Since refiners usually use the alcohol to raise the octane rating of
> their gasoline, I would recommend that you use premium grade gasoline to
> do this,so the resulting octane level will be high enough. '
> You can all have ethanol free gas if you want it. Problem solved!
I drained the water off the bottom because I made a tap to fit the top then inverted.
  Gas and OilTopic by: Richard Eberline Richard Eberline 10/06/18 10:05PM
  Re: Gas and OilRe: Richard Eberline Richard Eberline 10/06/18 10:24PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/06/18 10:53PM
  Re: Gas and OilRe: Seth B Seth B 10/06/18 11:01PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/06/18 11:43PM
  Re: Gas and OilRe: Seth B Seth B 10/06/18 11:54PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/07/18 12:02AM
  Re: Gas and OilRe: Seth B Seth B 10/07/18 01:12AM
  Re: Gas and OilRe: Stephen Keller Stephen Keller 10/07/18 01:27AM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/07/18 01:42AM
  Re: Gas and OilRe: . Chudas. . Chudas. 10/07/18 09:00AM
  Re: Gas and OilRe: jayson sumpter jayson sumpter 10/07/18 09:11AM
  Re: Gas and OilRe: Moped Jay Moped Jay 10/07/18 09:25AM
  Re: Gas and OilRe: Born to be WillD Born to be WillD 10/08/18 09:21AM
  Re: Gas and OilRe: P D P D 10/08/18 09:51AM
  Re: Gas and OilRe: Moped Lar Moped Lar 10/08/18 10:06AM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/08/18 09:47AM
  Re: Gas and OilRe: Born to be WillD Born to be WillD 10/10/18 08:07PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/10/18 08:09PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/10/18 08:43PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/10/18 09:17PM
  Re: Gas and OilRe: Born to be WillD Born to be WillD 10/14/18 09:25PM
  Re: Gas and OilRe: Thomas TPRF Thomas TPRF 10/08/18 09:52AM
  Re: Gas and OilRe: Josiah Radebaugh Josiah Radebaugh 10/08/18 10:43AM
  Re: Gas and OilRe: Bas Autowas Bas Autowas 10/08/18 10:44AM
  Re: Gas and OilRe: P D P D 10/08/18 11:27AM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 04:17PM
  Re: Gas and OilRe: P D P D 10/08/18 06:43PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 06:50PM
  Re: Gas and OilRe: P D P D 10/08/18 08:31PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 10:41PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 11:42PM
  Re: Gas and OilRe: P D P D 10/09/18 01:32AM
  Re: Gas and OilRe: Seth B Seth B 10/09/18 12:10PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/09/18 12:48PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/09/18 01:02PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 09:19PM
  Re: Gas and OilRe: Bas Autowas Bas Autowas 10/09/18 01:06PM
  Re: Gas and OilRe: Dusty Rim Dusty Rim 10/10/18 08:37PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/08/18 11:27AM
  Re: Gas and OilRe: P D P D 10/08/18 11:53AM
  Re: Gas and OilRe: Graham Motzing Graham Motzing 10/08/18 12:00PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/08/18 01:24PM
  Re: Gas and OilRe: Alex Gween Blastard Alex Gween Blastard 10/08/18 01:30PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/08/18 03:08PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/08/18 05:12PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/08/18 05:14PM
  Re: Gas and OilRe: . . . . 10/15/18 08:40AM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/08/18 02:06PM
  Re: Gas and OilRe: Moped Jay Moped Jay 10/08/18 03:09PM
  Re: Gas and OilRe: P D P D 10/08/18 03:44PM
  Re: Gas and OilRe: Dusty Rim Dusty Rim 10/08/18 05:09PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 06:31PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/08/18 07:04PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/09/18 09:13AM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 02:40PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 09:41PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/09/18 10:19PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 10:40PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/09/18 11:02PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 11:12PM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/08/18 07:11PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/09/18 12:56PM
  Re: Gas and OilRe: Seth B Seth B 10/09/18 12:59PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/09/18 04:30PM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/09/18 05:17PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/09/18 06:10PM
  Re: Gas and OilRe: Seth B Seth B 10/09/18 08:12PM
  Re: Gas and OilRe: Thomas TPRF Thomas TPRF 10/10/18 01:55AM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/10/18 08:45AM
  Re: Gas and OilRe: Thomas TPRF Thomas TPRF 10/10/18 09:18AM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/10/18 12:25PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/10/18 12:22PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/10/18 04:46PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/10/18 05:36PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/15/18 04:38PM
  Re: Gas and OilRe: P D P D 10/15/18 05:46PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 06:16PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 06:44PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 07:30PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:26PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 08:27PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:30PM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/10/18 04:47PM
  Re: Gas and OilRe: P D P D 10/10/18 05:22PM
  Re: Gas and OilRe: Born to be WillD Born to be WillD 10/10/18 08:29PM
  Re: Gas and OilRe: . . . . 10/14/18 09:51PM
  Re: Gas and OilRe: niklaus _ niklaus _ 10/15/18 01:49AM
  Re: Gas and OilRe: Jonathan R Jonathan R 10/15/18 01:51AM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/15/18 06:44AM
  Re: Gas and OilRe: Richard Eberline Richard Eberline 10/15/18 11:26AM
  Re: Gas and OilRe: jayson sumpter jayson sumpter 10/15/18 02:13PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/15/18 12:42PM
  Re: Gas and OilRe: Yucka Plant Yucka Plant 10/15/18 01:40PM
  Re: Gas and OilRe: Seth B Seth B 10/15/18 04:02PM
  Re: Gas and OilRe: P D P D 10/15/18 05:55PM
  Re: Gas and OilRe: Stephen Keller Stephen Keller 10/16/18 03:44AM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/15/18 05:54PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/15/18 05:59PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:28PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 08:35PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:38PM
  Re: Gas and OilRe: Jonathan R Jonathan R 10/15/18 08:44PM
  Re: Gas and OilRe: P D P D 10/15/18 08:47PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:50PM
  Re: Gas and OilRe: P D P D 10/15/18 09:20PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 11:49PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/15/18 11:20PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 11:55PM
  Re: Gas and OilRe: . . . . 10/15/18 11:26PM
  Re: Gas and OilRe: . . . . 10/16/18 12:21AM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/16/18 04:15AM
  Re: Gas and OilRe: . . . . 10/16/18 07:49AM
