Re: Gas and Oil
Don Ohio /
> Don Ohio Wrote:
> YOUR LOSS, Dillon………..LOL! Capitals,mine.
Here's an excerpt from a post on here on HOW to remove ethanol from gasoline. This was written on 11-1-2006:
` NOTE: There IS a way to remove the Ethanol from gasoline,but it takes care and you waste a little gas doing it.
(1)If the gas is only 10-15% ethanol or less, you take a clean,CLEAR jug(so you can see thru it), and put water in..... about one-fifth of the jug's volume.This will absorb the alcohol in the gas.
(2)THEN fill the jug with gas and you will actually see the reaction of the alcohol LEAVING the gasoline to become part of the water on the bottom.
(3) The IMPORTANT thing to do next after 10 minutes have elapsed or more, is to pour off the pure gasoline that is above the layer of water/alcohol mix on the bottom of the jug.
(4)You MUST NOT pour ANY of the solution from the bottom layer into the tank.
(5) NOW you have pure gasoline with onlky a residue of alcohol remaining.
Since refiners usually use the alcohol to raise the octane rating of their gasoline, I would recommend that you use premium grade gasoline to do this,so the resulting octane level will be high enough. '
You can all have ethanol free gas if you want it. Problem solved!
  Gas and OilTopic by: Richard Eberline Richard Eberline 10/06/18 10:05PM
  Re: Gas and OilRe: Richard Eberline Richard Eberline 10/06/18 10:24PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/06/18 10:53PM
  Re: Gas and OilRe: Seth B Seth B 10/06/18 11:01PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/06/18 11:43PM
  Re: Gas and OilRe: Seth B Seth B 10/06/18 11:54PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/07/18 12:02AM
  Re: Gas and OilRe: Seth B Seth B 10/07/18 01:12AM
  Re: Gas and OilRe: Stephen Keller Stephen Keller 10/07/18 01:27AM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/07/18 01:42AM
  Re: Gas and OilRe: . Chudas. . Chudas. 10/07/18 09:00AM
  Re: Gas and OilRe: jayson sumpter jayson sumpter 10/07/18 09:11AM
  Re: Gas and OilRe: Moped Jay Moped Jay 10/07/18 09:25AM
  Re: Gas and OilRe: Born to be WillD Born to be WillD 10/08/18 09:21AM
  Re: Gas and OilRe: P D P D 10/08/18 09:51AM
  Re: Gas and OilRe: Moped Lar Moped Lar 10/08/18 10:06AM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/08/18 09:47AM
  Re: Gas and OilRe: Born to be WillD Born to be WillD 10/10/18 08:07PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/10/18 08:09PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/10/18 08:43PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/10/18 09:17PM
  Re: Gas and OilRe: Born to be WillD Born to be WillD 10/14/18 09:25PM
  Re: Gas and OilRe: Thomas TPRF Thomas TPRF 10/08/18 09:52AM
  Re: Gas and OilRe: Josiah Radebaugh Josiah Radebaugh 10/08/18 10:43AM
  Re: Gas and OilRe: Bas Autowas Bas Autowas 10/08/18 10:44AM
  Re: Gas and OilRe: P D P D 10/08/18 11:27AM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 04:17PM
  Re: Gas and OilRe: P D P D 10/08/18 06:43PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 06:50PM
  Re: Gas and OilRe: P D P D 10/08/18 08:31PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 10:41PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 11:42PM
  Re: Gas and OilRe: P D P D 10/09/18 01:32AM
  Re: Gas and OilRe: Seth B Seth B 10/09/18 12:10PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/09/18 12:48PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/09/18 01:02PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 09:19PM
  Re: Gas and OilRe: Bas Autowas Bas Autowas 10/09/18 01:06PM
  Re: Gas and OilRe: Dusty Rim Dusty Rim 10/10/18 08:37PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/08/18 11:27AM
  Re: Gas and OilRe: P D P D 10/08/18 11:53AM
  Re: Gas and OilRe: Graham Motzing Graham Motzing 10/08/18 12:00PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/08/18 01:24PM
  Re: Gas and OilRe: Alex Gween Blastard Alex Gween Blastard 10/08/18 01:30PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/08/18 03:08PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/08/18 05:12PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/08/18 05:14PM
  Re: Gas and OilRe: . . . . 10/15/18 08:40AM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/08/18 02:06PM
  Re: Gas and OilRe: Moped Jay Moped Jay 10/08/18 03:09PM
  Re: Gas and OilRe: P D P D 10/08/18 03:44PM
  Re: Gas and OilRe: Dusty Rim Dusty Rim 10/08/18 05:09PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/08/18 06:31PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/08/18 07:04PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/09/18 09:13AM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 02:40PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 09:41PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/09/18 10:19PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 10:40PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/09/18 11:02PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/09/18 11:12PM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/08/18 07:11PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/09/18 12:56PM
  Re: Gas and OilRe: Seth B Seth B 10/09/18 12:59PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/09/18 04:30PM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/09/18 05:17PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/09/18 06:10PM
  Re: Gas and OilRe: Seth B Seth B 10/09/18 08:12PM
  Re: Gas and OilRe: Thomas TPRF Thomas TPRF 10/10/18 01:55AM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/10/18 08:45AM
  Re: Gas and OilRe: Thomas TPRF Thomas TPRF 10/10/18 09:18AM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/10/18 12:25PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/10/18 12:22PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/10/18 04:46PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/10/18 05:36PM
  Re: Gas and OilRe: Dirty30 Dillon Dirty30 Dillon 10/15/18 04:38PM
  Re: Gas and OilRe: P D P D 10/15/18 05:46PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 06:16PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 06:44PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 07:30PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:26PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 08:27PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:30PM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/10/18 04:47PM
  Re: Gas and OilRe: P D P D 10/10/18 05:22PM
  Re: Gas and OilRe: Born to be WillD Born to be WillD 10/10/18 08:29PM
  Re: Gas and OilRe: . . . . 10/14/18 09:51PM
  Re: Gas and OilRe: niklaus _ niklaus _ 10/15/18 01:49AM
  Re: Gas and OilRe: Jonathan R Jonathan R 10/15/18 01:51AM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/15/18 06:44AM
  Re: Gas and OilRe: Richard Eberline Richard Eberline 10/15/18 11:26AM
  Re: Gas and OilRe: jayson sumpter jayson sumpter 10/15/18 02:13PM
  Re: Gas and OilRe: Probably Fred Probably Fred 10/15/18 12:42PM
  Re: Gas and OilRe: Yucka Plant Yucka Plant 10/15/18 01:40PM
  Re: Gas and OilRe: Seth B Seth B 10/15/18 04:02PM
  Re: Gas and OilRe: P D P D 10/15/18 05:55PM
  Re: Gas and OilRe: Stephen Keller Stephen Keller 10/16/18 03:44AM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/15/18 05:54PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/15/18 05:59PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:28PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 08:35PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:38PM
  Re: Gas and OilRe: Jonathan R Jonathan R 10/15/18 08:44PM
  Re: Gas and OilRe: P D P D 10/15/18 08:47PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 08:50PM
  Re: Gas and OilRe: P D P D 10/15/18 09:20PM
  Re: Gas and OilRe: live ɘvil live ɘvil 10/15/18 11:49PM
  Re: Gas and OilRe: Don Ohio Don Ohio 10/15/18 11:20PM
  Re: Gas and OilRe: Andrew Squiggman Andrew Squiggman 10/15/18 11:55PM
  Re: Gas and OilRe: . . . . 10/15/18 11:26PM
  Re: Gas and OilRe: . . . . 10/16/18 12:21AM
  Re: Gas and OilRe: Trent Anderson Trent Anderson 10/16/18 04:15AM
  Re: Gas and OilRe: . . . . 10/16/18 07:49AM
