Gas and Oil
Richard Eberline /
I use ethanol free gas, 91 octane.
The gas station is a few miles away that sells it.
Why, ethanol absorbs water. Google this claim
Ethanol doesn't mix well with oil and separates. Google this claim.
Ethanol gas has a shorter self life and starts to layer. Google this claim.
The Oil I use, Red Line 2 Stroke Racing Oil. To me its one of the best oils.
Hold your roll, there are better. I did alot of research on my choice.
The company has been around for a long time, they have a R&D
department. Air cooled 2 stroke engine under 100cc's, They rate in the top ten.
Priced within my budget.
Just a reminder, I did my own research.
Re: Gas and Oil
Richard Eberline /
I know, i use any old gas.
I know, I use the cheapest oil
I know, i do 65 MPH on the cheapest gas and oil mix.
Good for you
Re: Gas and Oil
Probably Fred /
> Good for you
Yep that’s me!
I only can get crap ohio 87 octane 5-10% alcohol gas
And it’s mixed with Walmart synthetic 2 stroke oil
or any brand synthetic oil really,
You know what my bikes can do/how they run ,
Re: Gas and Oil
I'm with you. I run ethanol free, 91 octane as well. For the same true reasons. Red Line is good oil. I use Klotz TechniPlate, usually. Bel-Ray if I'm in a pinch and have to buy it local.
Plus, after ethanol and gasoline separate, and the petrol evaporates, you're left with a chunk of corn-colored plastic in the bottom of your tank and carburetor.
Re: Gas and Oil
You can make any gasoline ethonal free instead of paying a dollar or more per gallon for "recreational gas"
Re: Gas and Oil
Yeah, but my time and effort is worth more than $1/gallon.
Re: Gas and Oil
Its not like you have to sit and watch or wait on 10 gallons to seperate on its own.
Shaken not stirred
Get too used to being spoon fed and whatta ya gonna do when things get bad??????? (edited)
Re: Gas and Oil
> on its own.
> Shaken not stirred
> bad???????
Pedal, not make gas.
I get your point. A few years back before we left Kentucky, the Wife and I went the homestead, make your own everything route for a while. I learned how to make a lot of really cool, hillbilly engineered shit, but I don't mind paying for convenience, when it's available, and when I can afford it.
Re: Gas and Oil
I rock the ethanol free, as there is a station near me that has it, I run it in my old truck too, but my bikes run fine on regular, but for moped fuel needs the extra $ is worth it to me especially when putting bikes into storage. I like Castrol 2t or Yamalube for oil, Yamalube has run very clean for me,
Re: Gas and Oil
Andrew Squiggman /
Why do everyone in Ohio double space and only use one line sentences?
Re: Gas and Oil
I use propane and crisco
Re: Gas and Oil
Re: Gas and Oil
Cheapest gas and used motor oil
The Kawasaki doesn't seem to mind
Re: Gas and Oil
You can use whatever you want... the reason people fight it is because they dont appreciate the spreading of misinformation.
Specifically it is misinformed to claim or imply that you can only run non ethanol and high quality oil, especially in light of enormous evidence to the contrary, which is what everyone is contributing to by saying they do not use $$$gas or oil.
In short, can you use ethanol, and expensive oil? Yes. These are, except certain rare extremes, nowhere near requiring it. If the bike is ridden infrequently ethanol free maybe is worth it?
Honestly though I've never had or heard of anyone having real problems with ethanol, only stubborn purists claiming possible negative outcomes which never materialize...
Or things like dissolving floats, embrittling fuel lines? I'd 100x rather replace a float and fuel line once every few years than go an extra 10 miles a week and pay $1/gal just to avoid it....
Re: Gas and Oil
I love poking the bear.
Suppose your name is "Colin" and you are 23 and your first and only motorized vehicle is a vintage moped. "Colin" lives 25 miles from the only gas station in the area that sells ethanol free gasoline.
"Colin" can't really stockpile large quantities of ethanol free gas where he lives because he can only carry the gas in his tank plus a one gallon plastic jug of gas that he can carry on his vintage moped.
By the time he drives his moped 50 miles round trip to get some ethanol free gas for his moped, his tank is running on reserve, so he can either spend all his time riding to and from the correct gas station only or he can carry some 2-cycle oil with him and mix gas whenever he needs to fuel up at ANY gas station.
Since he burns through a tank of ethanol gas in a matter of a day, how much "damage" to his rubber seal in his petcock or plastic fuel line will he do in a day? What else can he "damage" on his Pinto when his gas tank is always empty due to the amount of driving he does?
I have no doubt that real gas mixes with 2-cycle oil better, runs better, doesn't separate, doesn't turn into plastic when it evaporates in the tank, etc, but will it do all that in a matter of the 3 hours it takes "Colin" to empty his tank because he loves riding the bike so much?
A wise man told me something like "drive it till it dies, then rebuild it." His initials are "R.E."
Re: Gas and Oil
I run what's available . And , yes I replace hard fuel lines and have to clean the yellowish crap out of the carbs that even the best filters can not stop .
True , some fuel is better than others for various reasons , but , I still have to do maintenance that wasn't required before ethanol was a thing .
Either way , I guess we should be glad that we can still run our toys cheaply .
Re: Gas and Oil
In any of my motors I've only had real issues with ethanol when they've sat long periods of time. That usually means lawnmower or weed whacker over winter. I've read time and time again that ethanol can attack plastic and rubber bits, but I'm mostly fooling with stuff that's so old all those parts are dryrotted and done anyway.
I do fill the cans I keep at home with marine fuel as I figure they may sit for months and I live in a marsh. When I'm out blasting I fill up with whatever. I follow a friend's advice and don't buy hightest fuel from gas stations in poorer neighborhoods as it's more likely to be funky as it isn't used as much.
For oil I buy Yamalube online, Lucas at O'Reilly's, and if I've really run out the cheap one shotters at the gas station.
I know if you're tuning is on the edge these things may seriously matter but for the most part I think fuel issues come from bad tanks and lack of use. You can't expect to let an engine sit for six months with a quarter gallon of fuel in a forty year old tank and the system not get gummed up.
Re: Gas and Oil
If you're worried about ethanol, just add a little Star-Tron to your full gas tank if it's gonna sit for a few months. I do this for all my bikes and power equipment and never have a problem with the ethanol gelling over. Star-Tron will keep your gas fresh for up to two years.
Re: Gas and Oil
Josiah Radebaugh /
One gallon-o 87 in an old jerry can and 1/3 cup-o lucas oil.
I'd like to find some low ethanol fuel but ya know. Also I've thought about getting 97 but... Does it even matter?
Re: Gas and Oil
No, its just mopeds.
Re: Gas and Oil
BTW , premixed fuel is stabilized as good as any fuel with a stabilizer added .
I don't have any on line scientific proof . Just my own experience .
A short story : I 'inherited' an old Eska outboard motor from a brother in law . It had quit running some twenty plus years before . Along with the motor came a gas tank with a palm pressure pump in line . I torn the motor apart and repaired what was wrong . I went to go fill the tank , but , it was already full and had been since the motor quit twenty some years past . Being a sealed tank , I took a chance and hooked it up to the motor . Guess what , that motor ran just fine on that antiquated premixed fuel . (edited)
Re: Gas and Oil
Dirty30 Dillon /
If your life is so worry-free that you have time to worry about sourcing ethanol-free gas for your 40 year-old toy motorcycle just so you can use the same fuel line and seals for the next 20 years, than you might as well just refine the stuff yourself.
It's ok to have an opinion, but if your supporting argument is "Google the info," you clearly are a troglodyte.
Re: Gas and Oil
But , isn't that exactly how life is suppose to be ? ;)
Re: Gas and Oil
seriously what the fuck oil threads, ugh.
Re: Gas and Oil
The less ethanol, the better for small engines. Don't know about now, but Stihl used to void warranties on people buying the cheap,ethanol gas. They tested it when the customer brought in the problem engine.
That was before the stupid gov't made it almost impossible to get gas without ethanol. The customer had a choice then, so Stihl punished them for it.
Now you all can SAY that ethanol doesn't hurt, but Stihl had scientific reasons for taking its use so seriously.
Re: Gas and Oil
And those reasons are saving money by finding a way to not honor a warranty
Re: Gas and Oil
They just got tired of seeing the damage ethanol was doing to their carbs and engine parts.
A company like Stihl values THEIR reputation. It has been a good one for the most part. People pay more to get Stihl quality.
Re: Gas and Oil
Dirty30 Dillon /
> them for it.
What reasons? Has Stihl published this, or do you have proof of voided warranties? The whole problem with this conversation is there is nothing to back it up. SO, it's all just hot air.
Re: Gas and Oil
Yet are made in China now hmm
Re: Gas and Oil
Like almost everything else .
Unless it was made in India . ;)
