Franco Morini M02 Thrust Bearing- Where to Get One?
Does anyone know of a supplier of thrust bearings for Franco Morini M02 engines.
It does not seem to be an off the peg standard size , so was presumably made by or especially for Franco Morini. As far as my slightly wonky micrometer will allow it is 47mm OD 36mm ID and about 4mm thick depending on whether you include the thickness of the ball bearing or not. The whole thing has 20 ball bearings. The bike in question is a British made BSA NVT Easyrider moped from the 1970s using the aforementioned Franco Morini engine. Any help greatly appreciated.
Re: Franco Morini M02 Thrust Bearing- Where to Get One?
Are you talking about the ring with all the bearings around the perimeter?
Larry? How many of those do you have?
I thought I had one more left, but I was mistaken. I must have sold them both to the last fella. My memory is not what it used to be. I still have one of those "fish hooks" that holds the end of the starter cable if you need it. Those can be hard to come by as well.
Yes,if you would,I'll take it. I'll PM you,Larry.
MopedLar comes thru again! We are really happy to have guys like you here,Larry.
Mark Crowder /
Yes its just a ring with 20 ball bearings in it , it fits in a cup which moves along a shaft when you pull the clutch/starter lever
You only need to have ball bearings at 3 or 4 points on that starter clutch bearing. As long as you have a ball at 120 degree, 240 degree, and 360 degree positions or at 90 degree,180 degree, 270 degree and 360 degree, you are good.
Extra balls in the holders don't matter as long as you have these positions covered or close to it.
But they need oil, so make sure the trans never runs very low of non-detergent 20W or 30W. The MO2 takes 15 oz. of oil.
Mark Crowder /
Thanks Don, i take it there is no one has a supply of these in the USA i am posting from Britain.
I don't know of anyone. Buy it from Italy,probably. The one with 3 ball bearings is fine. If you find an outlet ,you might want to buy the big washer that the bearings push against and the odd shaped bushing the whole starter clutch assembly rides on.
Mark Crowder /
We have a small stock of original Franco Morini M02 Clutch Cable Extenders and Cable End Trunnion at http://www.mopedbuglimited.co.uk/
If anyone needs one its on the website under BSA NVT Easyrider Engine parts
BSA NVT ER2 Easyrider Clutch Cable Extender 09-0719
and MO2 cable end BSA NVT ER2 Easyrider Starter Cable Trunnion 09-0523 Engine End £14.99 GBP each plus postage fully tracked to add on.
> parts
I want to thank you, Mark, for helping out in our Moped world. I'll be perusing that site for sure. Thanks, again! don-ohio
