Franco Morini M02 Thrust Bearing- Where to Get One?
Mark Crowder /
Does anyone know of a supplier of thrust bearings for Franco Morini M02 engines.
It does not seem to be an off the peg standard size , so was presumably made by or especially for Franco Morini. As far as my slightly wonky micrometer will allow it is 47mm OD 36mm ID and about 4mm thick depending on whether you include the thickness of the ball bearing or not. The whole thing has 20 ball bearings. The bike in question is a British made BSA NVT Easyrider moped from the 1970s using the aforementioned Franco Morini engine. Any help greatly appreciated.
