Hi Guy,
I’m wanting to extend my stator wiring and haven’t a clue what type to buy, any help would be much appreciated.
Thanks
Hi Guy,
Thanks
Maybe take a piece of what you have to your local hardware and buy equivalent or a touch bigger .
What?
14-18 AWG, stranded core wire.
What?
Danny,
Are you wanting to increase the length of the stator windings or lengthen the wiring harness that attaches to the stator itself?
Sorry, should have been clearer, I’m wanting to extend the stator cables that usually go to the connector block as I want to get rid of the block and connect everything under the cable cover.
Any flexible automotive wiring of the same guage will work. I like to use the same color shielding, solder connections and use heat shrink tubing to seal up.
