HPI wiring
JEDED OUT CasseroLLErs /
does anyone out there know of a way to wire in the break light when using an hpi that only offers one yellow wire for lights? i have been at this for a week now and have tried 3 different ways and still no luck
when i hook it up and activate brake the head light and tail running light turn off.
this is the hpi i am using
Re: HPI wiring
What bike? If the bike had the brake light circuit setup as a safety feature your going to need different switches.
Re: HPI wiring
its on a derbi flat reed
Re: HPI wiring
Do you have the right switches? Some setups require closed-at-rest switches some require open. That could throw you off. I don't see any reason they would be wired differently than any other brakes, so must be grounding something out when you pull the brakes
Stator>switch a
Switch a> switch b
Switch b> stop light
Re: HPI wiring
my brake sw are N/O
Re: HPI wiring
Fuck, I just wired one and trying to remember.....
Re: HPI wiring
my tail light is an LED one that has black wire for ground, blue wire is stop light and red wire is running light.
Re: HPI wiring
yellow wire should split into three wires...
-Wire one to headlight
-Wire one to tail light
-Wire one to N/O brake switch, then to brake light. Or it could go vice versa and you break the ground rather than supply power.
Re: HPI wiring
MAX LGN FTW. Yep, you just split the wire into three. And then make sure that the head and tail have a ground. I like to run power into both sides of the switch and then a wire out of each switch that joins somewhere, and goes all the way back to the brake light. I cannot remember if you need closed or open brake light switches for it to work. though.
Re: HPI wiring
Charles McCusker /
> though.
Are you saying run your brake light wire to both brake light switches then run em both back to the taillight?
Re: HPI wiring
You can either run power in and power out to each switch, or you can run a connector wire between the switches like many stock bikes do. I find the first way just easier and it creates a redundancy.
Re: HPI wiring
I would certainly suggest running a complete new wiring harness for the bike if you haven't already. Run yellow to both the voltage regulator and a flasher (also then run yellow from the voltage regulator to both headlight and tail light or a switch on your bars). On both brake switches you will run 1 wire to the brake light, and the other to the flasher. Make sure your grounds are secure and secluded. When I brake, my headlight dims a little, but I am running 2, 35 watt halogens. Be sure you also have the trail tech voltage regulator to keep up with the hpi. Hit me up if you want a diagram or something.
Re: HPI wiring
Charles McCusker /
I'm with you on the redundancy part. thanks man!
