Troubles
Well it's been a couples weeks since I replaced starter clutch pads. So today while it was up on the stand idling the pedals started slowly rotating , it wasn't , from vibrating, checked out WIKI, and it wasn't difficult changing it. But I'm puzzled . Any thoughts before I tear it apart again? Les, aka ,Monkey with a wrench.
Re: Troubles
Probably just the 30 year old grease in the freewheel
Re: Troubles
I'll double check it again but it looked clean when I had covers off, thanks Joe.
Re: Troubles
If it were a physical shift transmission , it was in neutral and the pedals /wheel started moving , I'd be a bit concerned .
It's not .
Re: Troubles
Maybe I oughta spray penetrating oil and double check the chain tension ? Can't hurt.
Re: Troubles
How fast is your idle speed?
Re: Troubles
It's low..
Re: Troubles
You're worrying TOO much . Ride that bike for all it's worth . Then take a break and admire what you have .
Re: Troubles
Your right PD, I'll take your advice, I'll wait for a rainy day, and look it over, take my time. Fire up the blue Bullet!
Re: Troubles
Your freewheel is likely stuck
Re: Troubles
It's on my to check list.. Thanks..
Re: Troubles
You're right, PD. It's Mopeds! They're easy to worry about though, and I tend to overthink things as well.
Ride it, Les! Take time to enjoy the ride. Then sit back, light a fat one, and pick the bugs out of your teeth from grinning all day!
Re: Troubles
You do know there's a repair section on the forum, right? Post up in there, some peeps only stick to certain sections, so might get more responses.
Re: Troubles
Will do.. also checked out WIKI... and my shop manual. Like Joe suggested I'm gonna check the free wheel.
Re: Troubles
Dirty30 Dillon /
Most people will say fuck it, as the grease in the freewheel can get goopy and drag like that.
I have had a freewheel lock, spin the pedals at 45 and throw me, so I don't fuck around. If it's janky I just replace it.
Re: Troubles
Well Dirty, I’m pretty sure you called. I took the chain off turned it clockwise, it took. Started counterclockwise, I could feel it grinding and catching. The bearings are bad. Fire up slow throttle and idle pedals rotate constantly and I put a lotta pressure to release. Oh well no biggie, I hope.
