WEIRD E-50 with square case covers
What type Puch did it come off of...? How do you get it started w/o drill.....?
Re: WEIRD E-50 with square case covers
More...
It looks like a dart motor except for that mechanism at the back of the transmission case. I've never seen that before. On the dart the starter clutch mechanism is built into the cover and is actuated with a cable.
Dirty30 Dillon /
Puch AD
Cleats Onionpockets /
That black wrinkle paint is SEXY
The dude that had it goes to Japan and lives in Hawaii... DART with missing clutch pressure plate and other missing parts....Looks like a ZA50 clutch cable fits...The round piece on the output gear is still unknown....
maybe they were intending to put a pull start on the ignition
I would do that over sourcing the other parts. Unless you could find another whole motor.....but I would just plug the holes and run a pull start.
> unknown....
If that tiny round piece moves with the main gear then it is probably some kinda auto engaging start.
Post a pic of the inside of the clutch cover. (edited)
Side cover has sprocket in it ....
Ah so the pedal crank/sprocket is on the right side and connects directly to the sprocket on the side cover with a chain, and then you only have a single chain running to the rear wheel.
I guess as I am finding this out myself....I just uploaded the Dart manual and in one of the pics I can see a chain coming out of the cover but the picture ends there...
That's so odd, look at the clutch engagement plate it's directly connected to the clutch.
My darts clutch is different than that. Way more posts but similar design.
