Re: No fuel in fuel line
Den 23 /
If you are saying that you can disconnect the fuel line from the carb and fuel flows just fine onto the ground but when you then reattach the line to the carb the fuel doesn't flow into the carb, try this: Attach a separate piece of fuel line to the carb only. Now blow lightly into the line to see if the path is clear. If it is not clear I can only see two things that the problem can be. As mentioned above, the float valve might be stuck closed. Or, the fuel inlet stub may be blocked. Let us know.
