throttle wont go below full/carb wont close
hey everyone. i cant figure this one out (it also happened randomly). every time i start up or ride my puch maxi the carb is always all the way open and wont go any less tan full speed. i tried messing with the carb screws but nothing worked. please help!
Re: throttle wont go below full/carb wont close
Maybe you need a throttle cable...or you could take off you carb and see if anything is causing your throttle to stick..
Ron Brown /
Louie,
This is one of those things you have to figure out yourself, because you can look at it.
When you twist the throttle, a slide in the carburetor is raised against a spring. When you close it, the spring pushes the slide back down,
So...you have a sticky cable or a sticky throttle slide.
You can check this by pulling on the cable at each end to see what is not moving.
Ron
