Looking for a little advice here, cant seem to get my garelli to want to start or stay running. I've replaced a bunch of parts on it recently to replace things that were missing/damaged.
so far here is what has been replaced on it:
new petcock/filter
cleaned the tank
dellorto 14/12 carb
new clutch setup
new sparkplug
cleaned the muffler out
I have gotten it to run a few times, had an issue idling so that is why i just replaced the clutch.
yesterday when i was trying to get it started after finishing up the clutch, the only way it would really start is if i had the throttle wide open and even then if i closed the throttle it would slow down and die. it did seem to run better with the 15/15 clone carb that came with it, but it seems like that was just dumping more fuel into it. when i changed the plug you could just smell and see some fuel leftover.
anyone have any tips on what i can check/adjust? still learning a little and not sure what check next.
