Re: Honda Hobbit not Starting
Marc Friedman /
. 14 mm at end of gauges to spark plug hole. Disconnect exhaust and intake. Get help.plugging holes with fingers but some corks or other might hold TOTALLY, and have 7 psi flowing in. Spray dilute baby shampoo over engine head gasket base gasket seals if u suspect a case leak everywhere and watch for expanding bubbles. It passes if it holds 7 psi with no bubbles. If it passes the likelihood of a leak is very low. Some folks will say that a classic leak down also instead of pumping air in at 7 psi creates a 7 psi vacuum. So there are various vacuum devices at say harbor freight which u can rig to do that if u want to go both ways. I can't argue that both ways is even better. Because it is.
Or alternatively spray some combustible substance like brake or carb cleaner. Please don't do that in NorCal so I have zero chance of having to have to take care of you in our burn unit.
  Honda Hobbit not StartingTopic by: Andrew Leone Andrew Leone 05/22/18 06:07PM
  Re: Honda Hobbit not StartingRe: Stephen Keller Stephen Keller 05/22/18 09:29PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:24AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:28AM
  Re: Honda Hobbit not StartingRe: Ryan . Ryan . 05/22/18 09:33PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:16AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:25AM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:35AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:57AM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 10:11AM
  Re: Honda Hobbit not StartingRe: alex ganz alex ganz 05/23/18 01:38PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 01:42PM
  Re: Honda Hobbit not StartingRe: Ryan . Ryan . 05/23/18 01:46PM
  Re: Honda Hobbit not StartingRe: pat splat pat splat 05/24/18 03:20PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 03:44PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 05:06PM
  Re: Honda Hobbit not StartingRe: taylor Vogel taylor Vogel 05/23/18 02:03PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/23/18 03:46PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 01:39PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 02:04PM
  Re: Honda Hobbit not StartingRe: Ryan Graeme Ryan Graeme 05/24/18 03:06PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 05:04PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 05:05PM
  Re: Honda Hobbit not Starting i got spark compression gas butRe: Carlos polanco Carlos polanco 01/28/21 02:22PM
