Re: Honda Hobbit not Starting
Marc Friedman /
U replaced the carb?? With an aftermarket keihin clone off of something like eBay?? The two I tried years ago were untuneable!! I have two oem ones that have been sitting clean in a hobbit carb box. Pm me if u want to buy one . Or simply post for one in the buy sell. If it's not ur seals it's the most likely culprit. U can replace the seals without disassembling the case if u carefully drill a sheetrock screw into the body of the seal without scoring either the crank or the case and use the screw to pull out the seal. Then press in the appropriate seals that treatland or does cycles can sell you with an appropriate ly sized socket.
  Honda Hobbit not StartingTopic by: Andrew Leone Andrew Leone 05/22/18 06:07PM
  Re: Honda Hobbit not StartingRe: Stephen Keller Stephen Keller 05/22/18 09:29PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:24AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:28AM
  Re: Honda Hobbit not StartingRe: Ryan . Ryan . 05/22/18 09:33PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:16AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:25AM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:35AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:57AM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 10:11AM
  Re: Honda Hobbit not StartingRe: alex ganz alex ganz 05/23/18 01:38PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 01:42PM
  Re: Honda Hobbit not StartingRe: Ryan . Ryan . 05/23/18 01:46PM
  Re: Honda Hobbit not StartingRe: pat splat pat splat 05/24/18 03:20PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 03:44PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 05:06PM
  Re: Honda Hobbit not StartingRe: taylor Vogel taylor Vogel 05/23/18 02:03PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/23/18 03:46PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 01:39PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 02:04PM
  Re: Honda Hobbit not StartingRe: Ryan Graeme Ryan Graeme 05/24/18 03:06PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 05:04PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 05:05PM
  Re: Honda Hobbit not Starting i got spark compression gas butRe: Carlos polanco Carlos polanco 01/28/21 02:22PM
