Re: Honda Hobbit not Starting
alex ganz /
> Andrew Leone Wrote:
> Could I test this by removing the reeds (I'll use the old reed assembly)
> so that it's completely open? Then test to see if it's pulling fuel
> through?
Sans reeds, pressurizing the chamber will be impossible as it will always be able to vent/draw from the atmosphere; this in turn would prohibit you from making it through a full cycle (so you wouldn't be able to tell anyway). Reeds are so easy to check, I have to agree with Dillon here - that's first (could be pinched, snapped, covered in sealant, etc.).
I assume from your first post that you're using an aftermarket carburetor and running premix? The assessment that "air is not being sucked through the carb" seems spot on, which leaves only a few likely culprits: reeds, intake, carb (I assume you're testing this with any air filters removed). Keep us posted.
  Honda Hobbit not StartingTopic by: Andrew Leone Andrew Leone 05/22/18 06:07PM
  Re: Honda Hobbit not StartingRe: Stephen Keller Stephen Keller 05/22/18 09:29PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:24AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:28AM
  Re: Honda Hobbit not StartingRe: Ryan . Ryan . 05/22/18 09:33PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:16AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:25AM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 09:35AM
  Re: Honda Hobbit not StartingRe: Dirty30 Dillon Dirty30 Dillon 05/23/18 09:57AM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/23/18 10:11AM
  Re: Honda Hobbit not StartingRe: alex ganz alex ganz 05/23/18 01:38PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 01:42PM
  Re: Honda Hobbit not StartingRe: Ryan . Ryan . 05/23/18 01:46PM
  Re: Honda Hobbit not StartingRe: pat splat pat splat 05/24/18 03:20PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 03:44PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 05:06PM
  Re: Honda Hobbit not StartingRe: taylor Vogel taylor Vogel 05/23/18 02:03PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/23/18 03:46PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 01:39PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 02:04PM
  Re: Honda Hobbit not StartingRe: Ryan Graeme Ryan Graeme 05/24/18 03:06PM
  Re: Honda Hobbit not StartingRe: Andrew Leone Andrew Leone 05/24/18 05:04PM
  Re: Honda Hobbit not StartingRe: Marc Friedman Marc Friedman 05/24/18 05:05PM
  Re: Honda Hobbit not Starting i got spark compression gas butRe: Carlos polanco Carlos polanco 01/28/21 02:22PM
