Cleaning a muffler on 78 Hobbit PA50II
Joshua Houseworth /
The manual (and wiki) says to just pop off the 1 screw and clean away, but I like the idea of loosening the carbon by way of the grill. Has anyone set theirs on a hot gas grill? I dont have a charcoal one. Or any ideas on how to thoroughly clean it (tools used, etc.). Thanks!
Re: Cleaning a muffler on 78 Hobbit PA50II
You don't need a grill, just make a little pit on the ground and burn it for about 30 min. Gas could work potentially but it needs to be near glowing hot.
Pull the pipe and apply a good amount of oven cleaner down the header pipe .
let is set for an hour or so . Garden hose it out and do it again .
Charles Cole (OFMC) /
Yes, the oven cleaner trick. Oven cleaner is Lye, a extremely strong chemical. I usually have a trash can full of a strong mix & dunk my pipes for several days. They come out right down to the metal if done on a regular basis. Will not distort the metal.
I just put some gas in mine and hang it on the fence and let it burn. Good idea...idk but it works okay enough. Just did a hobbit proma with moonshine heads.....
I've done the gas thing too , but the oven cleaner eats the carbon and doesn't try to burn anything down . ;)
Oh ya for sure much safer. Did oven clearner on Moby pipe. Came out nice.
Joshua Houseworth /
Thanks everyone. I think the oven cleaner suggestion will be my first choice!
