express headlight problems
so why did the brand new headlight that I just bought for my honda express burn out as soon as I started the ped? I followed the wiring diagram in the manual.
Re: express headlight problems
flannelman /
ok what year is the express because there is two wire in there that look the same but one is power and the other is a ground
i did the same thing when i did the rewiring on my 78 express
test the light for contentnewity
i dont know how to spell that last word i think it close
but there is three wire that come off of the head light blue green with a yellow strip and i cant rememer the other one i think it red or green i cant remeber off the top of my head
but the green with a yellow stip i mess up and put it were it shouldhave been and pop there 50 buck gone
Russ---
test your battery. I learned the hard way that:
1. the stock batteries are pure crap
2. a bad battery on an Express is a path into moped hell (detroit probably)
Get a replacement battery... it will be better quality and might solve the problem.
You might need to get a new sillicone (or silicon?) rectifier. it looks like a little relay that helps turn the raw AC from the ped into a stable DC that the battery likes.
yeah-- peds with batteries get all kinds of trouble... those bulbs aren't cheap either.
I ended up drilling out the back of one of the headlights, and adding a taillight bulb from a car... at least I could avoid buying those expensive bulbs, only to pop them,
The 12v bulb (on a 6v ped) wasn't bright.... no night riding, but I had a light at least.
I'm certain the problem is too much current cooking the filament in your headlamp... just not sure how to fix it.
I bet Ron B. will know... or someone who had an express and was good with electrical.
see if your battery holds a charge. Ed's battery will have a perfect replacement. they're in Westbrook, they sell me the gel-cells for my stereos.
Mine was a 78 too(headlight problems)
Russ... mine was a 78 express too-- keep that in mind a year or two could make all the difference.
The problems and ideas I had were from the bad experience with my bike.
Re: Mine was a 78 too(headlight problems)
Matt Wilson /
I bought a 6 Volt direct replacement for my peugeot headlamp. It is a sealed unit roughly 4in diameter and it only cost $10.
The part number was 4414, but 4511 has a bluish tint but the same bulb. They are direct replacements of the original.
Any local autoshop with a patient staff should be able to order them.
Matt
Ron Brown /
Russ,
You have all of the info you need in this thread,
Without the benefit of a diagram, you need either a new battery and/or a new rectifier/regulator. In any event, check with a voltmeter befire you plug the next one in.
Ron
