Before and after of my Batavus Starflite
Replaced the top end and clutch and exhaust and carb off a parts bike I scored for super cheap. Lots of other little replacement parts. Painted with duplicolor engine enamel.
It runs pretty well. 30mph version that probably maxes out around there on flat ground and is a bit slow in the low end. Idles perfectly.
To give an idea of cost to hopefully motivate others in their restoration efforts.... bought the bike for 360. Parts bike was 80. Between the cost of the bikes and paint and all of the other little parts probably $600-650 total. And a lot of time. I started out as a total total novices and still consider myself to be.
Thanks for everyone that responded to my questions along the way!
Re: Before and after of my Batavus Starflite
Charles Cole (OFMC) /
Very nice
Awesome! How did you clean up the fenders?
Jacob Gripes /
The front fender came off of the parts bike and was in really good shape. Used the aluminum foil trick and waxed it. The back fender confused me a bit. It seemed like bare aluminum but every thing I saw on these bikes suggested it was chromed. So maybe it was chromed aluminum that was completely flaked off. Anyway I used 1000 grit sandpaper and then buffing compound to get it close to looking like chrome.
Clean with good lines .
Nicely done . ;)
, its killing me, move the back of the tank up just a hair so the lines match up and post another pict
Pat , Just look at it a little cross-eyed . LOL
Jacob Gripes /
That should do it
Very clean. Nice!
> Jacob Hagood Wrote:
> https://i.imgur.com/gxxfqwe.jpg
> That should do it
^ Nice, the OCD can relax now! :) Great looking bike.
> Stephen Keller Wrote:
> > That should do it
Thanks, I was thinking the exact same thing. Self diagnosed OCD over here.
Joe Schuitema /
When I cleaned up mine, I found out the fenders were stainless steel. Made for easy weld repair and polishing.
Yeah the fenders seem to be either stainless or aluminum coated steel. Aluminum foil works great on the chrome everywhere else but I'm afraid it will scratch the fenders. I may try the 1000 grit.
Good job! Great bike!
don-ohio
Paul Boyer (OFMC) /
Wow!!! Congrats, IMHO you are not a novice anymore:)
Looks great! now that you've learned a lot, add a carb and weld on a chamber, that will help your all around performance with out much cash, or drastically altering the bike, if you wanna get nutz CrazyWayne has some insane porting for these things
Where’s the Hobbit motor?
I kid, nice bike. Glad you kept it original looking.
Just use a little degreaser on a rag, then a green scotch brite pad and some chrome polish to clean the fenders. (edited)
Jacob Gripes /
Thanks yeah I've found I'm not a huge fan of changing much. I thought I was going to get decals made but I like it as is.
Jacob Gripes /
I bought cheap polishing heads on Amazon for my drill and they worked pretty well.
Jacob Gripes /
Thanks. The more you learn the less you know and all that.
I'm with you .
Save the decals and stickers for the tool box . ;)
Jacob Gripes /
What carb would you recommend?
Jacob Gripes /
One issue I'm having is that the exhaust keeps melting my shoe....
At least you'll know they are your shoes . LOL
Maybe keep your foot a little farther away from the pipe ?
