Rebuilding at the office
Cleats Onionpockets /
Does this thing still work? Been a few years since I've logged on. The puch has been in hibernation for the past few years waiting for a proper paint job and rebuild, and at long last, it's finally coming back together.
Paint is complete, and I'm assembling one piece at a time on my lunch breaks. Will post updates as they happen.
Re: Rebuilding at the office
Part two. Apologies for the Barbara Walters soft lens.
Thats awesome! Wish I could work on mopeds during my lunch breaks
Just opened up the dirty crusty case that's going to get massively built for this, and thankfully it's a four bearing e50! *happy dance*
Braap Master Mope /
lunch-break office wrenching?? brilliant idea. cool office. nice bike. enjoy man!
Braap Master Mope /
do a victory lap around the cubicles when shes done
I'm sure his other co-workers will appreciate all the noise and excessive scent of 2-cycle exhaust indoors LOL
A Boy Named Britchez ... /
Welcome back Nathan!
I like that handlebar. I work at an auto shop and during my free time I work on my own shit. Feels like you're getting paid twice ;)
Same, I work at a bike shop in the office, but when I'm needing a break, I can go and wrench on company projects. On lunch, I can work on my own stuff, provided I use my own tools/supplies.
Thanks! Been a loooong time.
Are y'all ready for this? Y'all aren't ready for this. I'm getting excited over here.
Hard to tell in earlier shot, but I decided to go for a wrinkle paint. Love that vintage typewriter look.
That engine looks sooooo good. Excited to see this all together!
Korado top end arrived in the mail, Thanks Will!
Needed a quick cleaning in the bead blaster, and now I'm ready to start matching up the transfer ports.
Charles Cole (OFMC) /
Didn't realize how tiny the intake inlet is. A Dremel will come in handy. The blasting came out dandy! (edited)
This is so cool.
I guess there must have been two versions of the Korado top end. The one I had many years ago was the large port version, whereas this appears to be the small port. Maybe meant for a 12 or 14mm carb? The exhaust is equally tiny. Not for long, mind you. Dremel and files are at the ready.
If it came from Will it was probably made for a 12mm bing, standard size over here.
Hope you stuffed a block or foam or stuffed off the bore before blasting it
Not even a little bit. But I was very careful not to directly blast down the bore. As it's a used cylinder, I expected to re-hone it regardless. Cast iron bore, it will probably be fine. But if it's not, it'll get honed and hatched for maximum compression.
If new rings will be used in that cylinder , honing will be required .
Speedbump! Oh Noes!
Ho ho ho hoooooooo boy.
Getting excited.
Looking good! Iam digging the new stainless harware on the engine. The bead blasting came out sick.
Now that the mockups are done, time for the real work. Port matching with a carbide dremel bit, and a set of diamond files (harbor freight hey-ooo)
Part deux, lower half of case only. Going to do the upper half tomorrow and have my sandwich at the desk instead of the breakroom. Yolo.
Going with some modified trailer brake lights, with the incandescent bits swapped for LED. I'll be putting a rectifier/regulator on this build to keep those running cheerfully.
Nice work on that case match. Fast as hell to, knocked it out on a lunch break.
Thanks! It's only the bottom half of the case so far. We have a one hour lunch break here too, which helps mightily.
