Does anyone know the bulb used in the Peugeot 103 Veglia speedo?
It has a curious socket.... There's an indentation for a single bayonet not two like all the bulbs I've seen. Thanks!
Re: Does anyone know the bulb used in the Peugeot 103 Veglia speedo?
Could it be that's a screw in type socket ?
If so , the manual says it takes an E10 6 volt .6 watt single element bulb .
Here's the manual I took that from :
https://vintagemopeds.files.wordpress.com/2013/01/peugeot-103-clymer-manual.pdf (edited)
Jacob Gripes /
I guess it could be but there are no ridges for it. To me the outlet looks sort of like it was made for this.... http://www.lucky2strokes.com/product-p/honda_express_headlight_bulb.htm
Either was it won't break the bank. Thanks for the response.
That headlight bulb will never come close to fitting in the socket you picture . Way too big .
I'll yank a peugeot setup apart tomorrow and check. We have a ton of original bulbs so if I can match one up I'll list it for sale. Just not sure off the top of my head what it is.
Josiah Radebaugh /
It does take a small threaded 6 volt, I think .5 watt bulb. I bought a 6 volt 1.2 watt bulb from treatland. Its a wee bulb. Here's the treatland bulb.
Bad Cadillac™ /
> bulb.
That's not threaded though. It's a bayonet style (push and turn to lock).
Be careful with this if you dont have a regulated voltage supply o my 103 i fitted a bulb to mine and as i wasnt regulated the bulb over heated and the extra heat from the bulb melted the revolving numbers in the speedo!!!!!
Josiah Radebaugh /
Well, yes its not threaded but it still works.
