The whole tire or just a spot?
If just a section of the tire rubs on rotation, you need to have the wheel trued.
If one side is always touching, make sure the wheel is installed properly. The brake backing plate arm should register in the slot on the fork leg.
The washers on the axle should be under the nuts and in the recesses for them at the bottom of the fork leg.
Jim
