Re: front tire is way off
Jim C. /
The whole tire or just a spot?
If just a section of the tire rubs on rotation, you need to have the wheel trued.
If one side is always touching, make sure the wheel is installed properly. The brake backing plate arm should register in the slot on the fork leg.
The washers on the axle should be under the nuts and in the recesses for them at the bottom of the fork leg.
Jim
  front tire is way offTopic by: brian brian 06/25/02 04:13PM
  Re: front tire is way offRe: Jim C. Jim C. 06/25/02 04:31PM
  Re: front tire is way offRe: brian brian 06/25/02 04:33PM
  Re: front tire is way offRe: Ron Brown Ron Brown 06/26/02 09:45AM
  Re: front tire is way offRe: brian brian 06/26/02 01:49PM
  questionsRe: Mbartell Mbartell 06/26/02 02:01PM
  Re: front tire is way offRe: Ron Brown Ron Brown 06/26/02 04:35PM
