Re: Clean & polish aluminum Leleu hubs?
Charles Cole (OFMC) /
Started polishing MC hubs n parts back in the 60s. Lotsa ways to do it. I try to do it as time effective as possible and found it's much easier to keep a nicely polished surface brite with a minimal amount of work, however if you let it go, yes it will degrade. For round items use anything that will spin it. Mandrel from a proper fitting shaft, IE: axle, or in the case of a Hobbit, for instance, a tranny shaft mounted in a drill press or lathe. I don't throw away broken cranks cause they provide a mounting for parts that fit. I have a collection of shafts that can be used for mandrels. And for other parts lots of sanding after dremeling away casting imperfections, etc. Then my Baldor buffing motors, with plenty of different wheels and compounds. One compound to one wheel so there's no cross contamination. It just depends on how nice you want the final outcome to be. For nooks n crannies, easily made custom mandrels for the dremel is mandatory. About 80 hrs to mirror polish an entire Hobbit motor. Picture doesn't do it justice!
(edited)
  Clean & polish aluminum Leleu hubs?Topic by: Dmitry K. Dmitry K. 03/14/18 12:17AM
  Re: Clean & polish aluminum Leleu hubs?Re: frank dadog frank dadog 03/14/18 02:49AM
  Re: Clean & polish aluminum Leleu hubs?Re: no groms no blasters no groms no blasters 03/14/18 02:58AM
  Re: Clean & polish aluminum Leleu hubs?Re: no groms no blasters no groms no blasters 03/14/18 03:02AM
  Re: Clean & polish aluminum Leleu hubs?Re: Paul Boyer (OFMC) Paul Boyer (OFMC) 03/14/18 01:25PM
  Re: Clean & polish aluminum Leleu hubs?Re: jumpsuit steve jumpsuit steve 03/14/18 01:37PM
  Re: Clean & polish aluminum Leleu hubs?Re: frank dadog frank dadog 03/14/18 02:14PM
  Re: Clean & polish aluminum Leleu hubs?Re: Dmitry K. Dmitry K. 03/14/18 03:23PM
  Re: Clean & polish aluminum Leleu hubs?Re: Charles Cole (OFMC) Charles Cole (OFMC) 03/14/18 03:47PM
  Re: Clean & polish aluminum Leleu hubs?Re: frank dadog frank dadog 03/14/18 04:29PM
  Re: Clean & polish aluminum Leleu hubs?Re: Double Trouble Dan Double Trouble Dan 03/14/18 04:36PM
  Re: Clean & polish aluminum Leleu hubs?Re: P D P D 03/14/18 05:08PM
  Re: Clean & polish aluminum Leleu hubs?Re: Dmitry K. Dmitry K. 03/14/18 05:09PM
  Re: Clean & polish aluminum Leleu hubs?Re: Charles Cole (OFMC) Charles Cole (OFMC) 03/15/18 12:44AM
  Re: Clean & polish aluminum Leleu hubs?Re: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 03/14/18 08:16PM
  Re: Clean & polish aluminum Leleu hubs?Re: jumpsuit steve jumpsuit steve 03/14/18 10:44PM
  Re: Clean & polish aluminum Leleu hubs?Re: - schmiddy - schmiddy 03/14/18 10:55PM
  Re: Clean & polish aluminum Leleu hubs?Re: frank dadog frank dadog 03/15/18 12:54AM
  Re: Clean & polish aluminum Leleu hubs?Re: Charles Cole (OFMC) Charles Cole (OFMC) 03/15/18 01:05AM
  Re: Clean & polish aluminum Leleu hubs?Re: frank dadog frank dadog 03/15/18 01:36AM
  Re: Clean & polish aluminum Leleu hubs?Re: Paul Boyer (OFMC) Paul Boyer (OFMC) 03/18/18 07:05AM
  Re: Clean & polish aluminum Leleu hubs?Re: Charles Cole (OFMC) Charles Cole (OFMC) 03/18/18 05:37PM
  Re: Clean & polish aluminum Leleu hubs?Re: Ben Whittle Ben Whittle 03/18/18 06:10PM
  Re: Clean & polish aluminum Leleu hubs?Re: Charles Cole (OFMC) Charles Cole (OFMC) 03/18/18 06:30PM
  Re: Clean & polish aluminum Leleu hubs?Re: Ben Whittle Ben Whittle 03/18/18 08:53PM
  Re: Clean & polish aluminum Leleu hubs?Re: Dmitry K. Dmitry K. 03/18/18 10:35PM
  Re: Clean & polish aluminum Leleu hubs?Re: Ben Whittle Ben Whittle 03/20/18 11:27AM
  Re: Clean & polish aluminum Leleu hubs?Re: P D P D 03/20/18 11:49AM
  Re: Clean & polish aluminum Leleu hubs?Re: no groms no blasters no groms no blasters 03/20/18 05:40PM
  Re: Clean & polish aluminum Leleu hubs?Re: Double Trouble Dan Double Trouble Dan 03/20/18 08:08PM
  Re: Clean & polish aluminum Leleu hubs?Re: Ben Whittle Ben Whittle 03/20/18 08:37PM
  Re: Clean & polish aluminum Leleu hubs?Re: Charles Cole (OFMC) Charles Cole (OFMC) 03/25/18 03:56PM
  Re: Clean & polish aluminum Leleu hubs?Re: Ѭ ɞŦЯʚOluv Ѫѫ Ѭ ɞŦЯʚOluv Ѫѫ 03/20/18 09:58PM
