how is there a good way to get the decals off?? w/ a chemical or some soap and h20 or what!?
If they have been on there for years... they are probably going to leave dried adhesive on even when you get them off.
A heat gun is about the best way... you warm them up good... (leaving it in the hot sun might be good too).. then peel them off slowly.
I think there is also a solvent for getting the old adhesive off too... go ask at an auto parts store
use a blow dryer and some goo=off. If heating them up doesn't get them off u can try using a razor to get under them but it probably will scratch it so i wouldn't suggest that.
Yes.. Goo-Gone and the heat gun or hairdryer should work fine.
bob ross (that pbs painter but deceased guy) make a paletteknife that when used with goo gone took about 3 minutes to undrees my friend spree
