crank
How do I remove the crank on a puch maxi? I bent the crank and it is hitting my proma exhaust
Re: crank
The pedal crank?
Re: crank
yead. on the exhaust side.
Re: crank
Matt Wilson /
Toehead you probably didn't bend it. On my maxi the crank just clips the biturbo exhaust.
Its easier to bend the exhaust mount than to bend a crank.
To remove the crank loosen the 10mm bolt on the crank, by the axle. Then with a hammer hit the bolt away from the threaded side. If you bend the cotter pin (the proper name) you can get another from a bike shop for less than a dollar
Matt
Re: crank
okay, i'll try that. i put electrical tape on the exhaust to stop it from getting scratched while i waited for a reply. i'll try to bend the exhaust mount.
Re: crank
i can't seem to get it off. :(
Re: crank
Ron Brown /
Is the cotter pin stuck?
Re: crank
i don't even see a cotter pin. It is a puch newport L, a model of maxi.
Re: crank
Ron Brown /
Toehead,
I am not sure if your crank has them, but the cotter pin is the pin that passes through the crank next to the spindle and has a nut on one end. If you don't have this, what does hold your crank on?
Ron
Re: crank
yeah, i have that, but that's not what i call a cotte pin :) how do you get it out? I tried banging it with a a hammer, but it doesn't work. Anyway, i took a propane torch, heated the crank red hot, and bent it away from the exhaust :)
Re: crank
Ron Brown /
On a bicycle, it is called a cotter pin. Blame the English.
The end you see sticking out opposite the threaded end is as big as the pin gets, it has a yapered flat on one side which registers with a flat on the crank. To remove it, remove the nut, then whack the threaded end with a good hammer.
Ron
Re: crank
yeah, i did, and bent the treads.:( now i have to toch it up witha dremmel
