Re: Got my Sachs yesterday (63 miles)
Eric DeSachs /
> Born to be WillD Wrote:
> starter fluid is a good check too, works better and easier than gas in
> the plug hole. worth running some oiled gas thru 1st tho, starter fluid
> got no lube. but it doesnt hurt to use it for starting, really easy
> check if your issue is fuel.
> you mention the 2 tubes on the petcock. the longer one is normal flow,
> draws about an inch up. then if that runs out you switch to reserve and
> it draws out the very bottom giving you a lil extra range to refuel. If
> only one works you're either below the level of the normal flow, or one
> of the two is clogged. the reserve drawing from the bottom is easy to
> clog w rust n grit. if it gets thru the petcock tho, it does an even
> better job of clogging your jets so always worth putting a fuel filter
> in line.
> the clutches can be a challenge. sometimes they can get sorta scorched
> or hard and slip. also if the nut under the lil engagement bell on the
> clutch gets loose it'll turn the basket but not the crank. but i presume
> you checkd spark (i didnt read in huge detail above) and if you've got
> spark your engines turning over and the clutch is at least good enough
> to get you started.
> the other thing that gets left outta fred's guide but doesnt deserve to
> be left out for sachs is the decomp valve. I dont wanna bring it up too
> early - it can be a very convincing red herring, but the decomp valves
> can stick open or leak and that removed compression, making it easy to
> turn over but much harder to start. (a leaky one can still run however
> just poorly.)
> there's a buttload of details in sachs 505/1a performance if you search
> the wiki. youve got a huge leg up with a D engine already on yours but
> 90% of the rest of the tuning info and engine details apply.
This is such a great reply. Much appreciated.
I just got my gaskets and stuff from the moped junkyard (well... I got it a few days ago. Very fast shipping even during the holidays!!)
I’ll likely rebuild the carb; replace the gas lines; put in a new in line filter and see what I can do from there
  Got my Sachs yesterday (63 miles)Topic by: Eric DeSachs Eric DeSachs 12/18/17 09:10PM
  Re: Got my Sachs yesterday (63 miles)Re: Don Ohio Don Ohio 12/18/17 09:18PM
  Re: Got my Sachs yesterday (63 miles)Re: Peter Cooper Peter Cooper 12/18/17 10:15PM
  Re: Got my Sachs yesterday (63 miles)Re: Chris Straub Chris Straub 12/18/17 10:26PM
  Re: Got my Sachs yesterday (63 miles)Re: Road Kill Road Kill 12/18/17 10:39PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/19/17 06:10AM
  Re: Got my Sachs yesterday (63 miles)Re: MPB Andrew MPB Andrew 12/19/17 11:09AM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/19/17 07:45PM
  Re: Got my Sachs yesterday (63 miles)Re: Bas Autowas Bas Autowas 12/20/17 07:51AM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/20/17 08:27AM
  Re: Got my Sachs yesterday (63 miles)Re: MPB Andrew MPB Andrew 12/20/17 10:45AM
  Re: Got my Sachs yesterday (63 miles)Re: Don Sumpter (OFMC) Don Sumpter (OFMC) 12/20/17 11:54AM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/20/17 01:17PM
  Re: Got my Sachs yesterday (63 miles)Re: Don Sumpter (OFMC) Don Sumpter (OFMC) 12/21/17 02:44AM
  Re: Got my Sachs yesterday (63 miles)Re: Bad Cadillac™ Bad Cadillac™ 12/19/17 07:31AM
  Re: Got my Sachs yesterday (63 miles)Re: jayson sumpter jayson sumpter 12/19/17 09:04AM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/19/17 07:57PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/19/17 08:03PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/19/17 08:08PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/19/17 08:25PM
  Re: Got my Sachs yesterday (63 miles)Re: Chris Kirk Chris Kirk 12/19/17 09:18PM
  Re: Got my Sachs yesterday (63 miles)Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 12/20/17 02:48AM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/20/17 04:24AM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/23/17 05:23PM
  Re: Got my Sachs yesterday (63 miles)Re: C Colombo C Colombo 12/23/17 06:19PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/23/17 07:06PM
  Re: Got my Sachs yesterday (63 miles)Re: Chris Straub Chris Straub 12/23/17 07:12PM
  Re: Got my Sachs yesterday (63 miles)Re: Ken Roff Ken Roff 12/23/17 07:27PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/23/17 10:15PM
  Re: Got my Sachs yesterday (63 miles)Re: Chris Straub Chris Straub 12/23/17 10:44PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/23/17 10:53PM
  Re: Got my Sachs yesterday (63 miles)Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/24/17 10:58AM
  Re: Got my Sachs yesterday (63 miles)Re: P D P D 12/24/17 11:51AM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/24/17 12:07PM
  Re: Got my Sachs yesterday (63 miles)Re: P D P D 12/24/17 12:42PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/24/17 01:57PM
  Re: Got my Sachs yesterday (63 miles)Re: P D P D 12/24/17 02:28PM
  Re: Got my Sachs yesterday (63 miles)Re: Don Sumpter (OFMC) Don Sumpter (OFMC) 01/02/18 01:22PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/24/17 10:36AM
  Re: Got my Sachs yesterday (63 miles)Re: Charles Cole (OFMC) Charles Cole (OFMC) 12/24/17 02:22PM
  Re: Got my Sachs yesterday (63 miles)Re: Paul Boyer (OFMC) Paul Boyer (OFMC) 12/24/17 03:32PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/24/17 03:43PM
  Re: Got my Sachs yesterday (63 miles)Re: Chris Straub Chris Straub 12/24/17 04:44PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/24/17 04:59PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 12/24/17 05:15PM
  Re: Got my Sachs yesterday (63 miles)Re: Dave Gjessing Dave Gjessing 12/24/17 06:24PM
  Re: Got my Sachs yesterday (63 miles)Re: P D P D 12/24/17 07:12PM
  Re: Got my Sachs yesterday (63 miles)Re: P D P D 12/24/17 05:51PM
  Re: Got my Sachs yesterday (63 miles)Re: Chris Straub Chris Straub 12/24/17 05:47PM
  Re: Got my Sachs yesterday (63 miles)Re: Born to be WillD Born to be WillD 12/31/17 07:58PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 01/02/18 09:15PM
  Re: Got my Sachs yesterday (63 miles)Re: MPB Andrew MPB Andrew 01/03/18 05:08PM
  Re: Got my Sachs yesterday (63 miles)Re: Eric DeSachs Eric DeSachs 01/03/18 07:22PM
  Re: Got my Sachs yesterday (63 miles)Re: I ain't had citrus for a month, and I'm RARIN' for a kill I ain't had citrus for a month, and I'm RARIN' for a kill 12/31/17 08:46PM
  Re: Got my Sachs yesterday (63 miles)Re: P D P D 12/31/17 09:09PM
Want to reply to this thread?
