TTLX turn signal/brake light wiring issue
Drew Matthews /
Hey guys, I’ve got a turn signal and brake light issue that l just can’t figure out. I’ve got an LED taillight with turn signals so I’m assuming l need some sort of resistor to make the turn signals work? The flasher relay has a steady current going through it even when the turn signals are not on which seems odd..
Obviously l have no idea what I’m doing so any advice would be awesome. Thank you!!Edited 1 time(s). Last edit at 12/03/17 07:14PM by drew_matthews.
Click here to login.
