Re: Oil Ratio: 1978 PA50
frank dadog /
> Steven Kwak Wrote:
> Wrong a lean charge Burns faster so you get a more complete burn in the
> cylinder at a higher temperature and less heat in the pipe.
> When do you use an oxy acetylene torch it's oxygen that makes it burn
> the steel.
> This Thread is just so fucked up with bad info.
NO.
Please stop spreading false information. If you don't know Google it, I've explained it so anyone can understand but feel free to read up on the combustion process.
  Oil Ratio: 1978 PA50Topic by: Dean Shearsmith Dean Shearsmith 10/22/17 12:12PM
  Re: Oil Ratio: 1978 PA50Re: Don Sumpter (OFMC) Don Sumpter (OFMC) 10/22/17 12:59PM
  Re: Oil Ratio: 1978 PA50Re: Ryan . Ryan . 10/22/17 02:17PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/28/17 06:56PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/28/17 07:18PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/28/17 07:27PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/28/17 07:34PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/28/17 08:20PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 11:33AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/29/17 01:08PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 01:28PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/29/17 01:31PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/29/17 02:10PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 02:55PM
  Re: Oil Ratio: 1978 PA50Re: Charles Cole (OFMC) Charles Cole (OFMC) 10/29/17 10:20AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/29/17 12:02PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 12:26PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/29/17 01:32PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 02:56PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/29/17 03:39PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 04:07PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/29/17 03:51PM
  Re: Oil Ratio: 1978 PA50Re: Charlie BUZZARD Charlie BUZZARD 10/29/17 12:39PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 01:00PM
  Re: Oil Ratio: 1978 PA50Re: Charlie BUZZARD Charlie BUZZARD 10/29/17 08:28PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/30/17 12:20AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/30/17 03:24PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/30/17 10:00PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/30/17 10:15PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/30/17 10:40PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/30/17 10:45PM
  Re: Oil Ratio: 1978 PA50Re: Ryan . Ryan . 10/29/17 01:02PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/30/17 10:41PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/31/17 12:36AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 01:35AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/31/17 08:32AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 10:09AM
  Re: Oil Ratio: 1978 PA50Re: jayson sumpter jayson sumpter 10/31/17 10:21AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/31/17 03:38PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 04:58PM
  Re: Oil Ratio: 1978 PA50Re: jayson sumpter jayson sumpter 10/31/17 05:00PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 10:18AM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/31/17 11:59AM
  Re: Oil Ratio: 1978 PA50Re: Stephen Keller Stephen Keller 10/31/17 02:34PM
  Re: Oil Ratio: 1978 PA50Re: Mark Booth Mark Booth 10/31/17 04:06PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 02:36AM
  Re: Oil Ratio: 1978 PA50Re: Dean Shearsmith Dean Shearsmith 10/31/17 07:40PM
  Re: Oil Ratio: 1978 PA50Re: Charlie BUZZARD Charlie BUZZARD 10/31/17 04:31PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 08:35PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 09:45AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 10:50AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 12:14PM
  Re: Oil Ratio: 1978 PA50Re: Charlie BUZZARD Charlie BUZZARD 11/01/17 12:20PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 01:20PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 03:18PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 04:32PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 08:18PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 08:53PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 09:20PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 09:26PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 09:34PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 09:52PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 10:19PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 11:57AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 02:40PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 02:53PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 03:21PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 04:44PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 08:24PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 09:04PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 09:07PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 09:13PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 10:37PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 11:09PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/02/17 03:11AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/02/17 09:28AM
  Re: Oil Ratio: 1978 PA50Re: jayson sumpter jayson sumpter 11/02/17 09:30AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/02/17 10:00AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/02/17 10:08AM
