> Lolita ✌ Wrote:
> When will it seize?
Nobody claimed your engine would seize if you didn't use synthetic.
I don't get it dude, you have a valid point, you don't need hyperbole to make it. Synthetics have some beneficial properties in certain applications, most of which none of us will ever experience. Conventional oils can be used to virtually the same effect without the the added cost. At the end of the day there's no substitute for proper care and maintenance.
