> Lolita ✌ Wrote:
> > > > Steven Kwak Wrote:
> > You need to pull your face out of your girlfriend and do a little
> > research.
> I'm hungry. Pussy tastes good.
> > > > Steven Kwak Wrote:
> > If you run a heavy oil mix and or cheap oil in a tight clearance
> motor.
> > The oil will actually break down and begin to jail and gum.
> Any evidence?
> Oil price makes no difference.
> > > > Steven Kwak Wrote:
> > This increases friction causing the Piston to expand.
> > This causes the oil to gum and sticking to the point even the gas
> cannot
> > act as a thinning solvent.
> > Your head temps will appear fine but the Piston is drastically
> > overheating due to the increase sidewall friction.
> > Then your engine will seize.
> When will it seize?
> 30:1 for over a decade.
Nice try but you're just talking to the hand or in this case your fist rattling around in the hallway.
And I'm not going to continue with this conversation you're just looking for an argument you lost.
