Re: Oil Ratio: 1978 PA50
Lolita ✌ /
> frank dadog Wrote:
< then you state "less fuel doesn't cause
> overheating".
Blind as a fucking bat. Read my post again. I stated more OIL doesn't cause overheating.
> frank dadog Wrote:
> More oil in the mix displaces fuel from the charge, leads
> to lean conditions and more heat.
> When your argument contradicts itself it's time to reevaluate your
> argument.
> Synthetic oils have less impurities. They perform better at higher and
> low temperatures and they don't break down as fast as conventional oils.
> This is all proven science.
> You don't seem to have much of an argument. You just want to call people
> stupid for using synthetics. If you think it's stupid to spend extra
> money on synthetics that's your opinion and you're entitled to it. I
> don't find it "necessary" either. But you look foolish trying to change
> the facts just to suit your opinion.
Petroleum is not "bad oil" for fucks sake. You failed to provide those links to scientific evidence.
"More oil in the mix displaces fuel from the charge, leads to lean conditions and more heat."... What a load of unsubstantiated drivel.
  Oil Ratio: 1978 PA50Topic by: Dean Shearsmith Dean Shearsmith 10/22/17 12:12PM
  Re: Oil Ratio: 1978 PA50Re: Don Sumpter (OFMC) Don Sumpter (OFMC) 10/22/17 12:59PM
  Re: Oil Ratio: 1978 PA50Re: Ryan . Ryan . 10/22/17 02:17PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/28/17 06:56PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/28/17 07:18PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/28/17 07:27PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/28/17 07:34PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/28/17 08:20PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 11:33AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/29/17 01:08PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 01:28PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/29/17 01:31PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/29/17 02:10PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 02:55PM
  Re: Oil Ratio: 1978 PA50Re: Charles Cole (OFMC) Charles Cole (OFMC) 10/29/17 10:20AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/29/17 12:02PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 12:26PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/29/17 01:32PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 02:56PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/29/17 03:39PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 04:07PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/29/17 03:51PM
  Re: Oil Ratio: 1978 PA50Re: Charlie BUZZARD Charlie BUZZARD 10/29/17 12:39PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/29/17 01:00PM
  Re: Oil Ratio: 1978 PA50Re: Charlie BUZZARD Charlie BUZZARD 10/29/17 08:28PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/30/17 12:20AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/30/17 03:24PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/30/17 10:00PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/30/17 10:15PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/30/17 10:40PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/30/17 10:45PM
  Re: Oil Ratio: 1978 PA50Re: Ryan . Ryan . 10/29/17 01:02PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/30/17 10:41PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/31/17 12:36AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 01:35AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/31/17 08:32AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 10:09AM
  Re: Oil Ratio: 1978 PA50Re: jayson sumpter jayson sumpter 10/31/17 10:21AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 10/31/17 03:38PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 04:58PM
  Re: Oil Ratio: 1978 PA50Re: jayson sumpter jayson sumpter 10/31/17 05:00PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 10:18AM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 10/31/17 11:59AM
  Re: Oil Ratio: 1978 PA50Re: Stephen Keller Stephen Keller 10/31/17 02:34PM
  Re: Oil Ratio: 1978 PA50Re: Mark Booth Mark Booth 10/31/17 04:06PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 02:36AM
  Re: Oil Ratio: 1978 PA50Re: Dean Shearsmith Dean Shearsmith 10/31/17 07:40PM
  Re: Oil Ratio: 1978 PA50Re: Charlie BUZZARD Charlie BUZZARD 10/31/17 04:31PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 10/31/17 08:35PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 09:45AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 10:50AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 12:14PM
  Re: Oil Ratio: 1978 PA50Re: Charlie BUZZARD Charlie BUZZARD 11/01/17 12:20PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 01:20PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 03:18PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 04:32PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 08:18PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 08:53PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 09:20PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 09:26PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 09:34PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 09:52PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 10:19PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 11:57AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 02:40PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 02:53PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 03:21PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 04:44PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 08:24PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 09:04PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 09:07PM
  Re: Oil Ratio: 1978 PA50Re: Lolita ✌ Lolita ✌ 11/01/17 09:13PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/01/17 10:37PM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/01/17 11:09PM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/02/17 03:11AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/02/17 09:28AM
  Re: Oil Ratio: 1978 PA50Re: jayson sumpter jayson sumpter 11/02/17 09:30AM
  Re: Oil Ratio: 1978 PA50Re: frank dadog frank dadog 11/02/17 10:00AM
  Re: Oil Ratio: 1978 PA50Re: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 11/02/17 10:08AM
