new guy with new kreidler flory!
hey hey all!! brand new guy here just registered! I Just bought 3 days ago a 1977 Kreidler Flory, don't know anything about it, or what exact model it is... has spark, turns over but I Need a carb and throttle cable twist assy before I can even see if she fires! anyways here she is!! :)
Re: new guy with new kreidler flory!
Cool pipe. Most kreidler bent pipes are black with chrome tip.
I’ve never seen a blue flory, most are orange.
Throttle twist is the same as any Puch and a stock Puch 12mm bing will work.
thanks for the throttle twist and carb info Boot 2Thehead!!
I do think it was repainted as I see some orange underneath :(
I measured the intake manifold and it's approx. 16mm so does that mean I Need a 16mm carb?
Yes, I Love that pipe too!! :)
The stock carb for your bike is a bing 1/12/260 with a 68 jet.
Look in the wiki section as it has plenty of good info on kreidler.
I found a real sweet lookin bing 1/12/293 with a 72 main, whats the difference between it and the 1/12/260?
Downhill Harvey (OFMC) /
Looks like the switch's are janked. Kreidlers have a hi-lo beam headlight. Check headlight for a dual filament bulb/socket.
Also remove both chains, and shocks, and rear wheel, to check for swing-arm play/slop. Every Kreidler I have seen needed swing-arm bushings.
Use only 20w, or 30w non-detergent oil in the tranny, or risk the clutch linings falling off.
http://www.myronsmopeds.com/category/parts/kreidler-parts/
http://projectmopedmanual.info/Manuals/Kreidler/Kreidler%20service%20manual.pdf
thanks very much Downhill Harvey (OFMC)!!! great links!!
hoping someone could steer me in the right direction regarding my throttle, bikes I've worked on usually have a 2 piece collar that holds the throttle tube from sliding off the bars... I checked the parts manual/diagram and I don't get it, nothing like what I expect, do I only need the throttle tube and grip and I'm good?
Welcome to the site! I’ve always loved the look of a Kreidler.
Kreidlers sold in the states are not fast, but I love the way they ride.
Paul Boyer (OFMC) /
Nice score Greg!!! Finally another North Bayite.
Nice score!!
I disagree with the needing bushings, I've owned several bikes and never needed em. But if you decide to do this, you can buy replacements from several locations, or take measurements + find brass bushings from a hardware supply company:
https://www.ebay.de/itm/Kreidler-Florett-K54-RM-RMC-RMC-S-Schwingenachse-Schwingen-Achse-Buchsen-NEU/222594684430
https://www.treatland.tv/kreidler-pedal-shaft-w-bushings-14mm-OD-shaft-p/kreidler-pedal-shaft-10001.htm
https://www.ebay.de/itm/Kreidler-Florett-Schwingen-Lagerbuchse-Paar-Neu/151354066814?
I recently rebuilt my Kreidler MP-19 and documented where I found everything: https://www.mopedarmy.com/forums/read.php?7,4083181
my kindergarten teacher was named mrs. flory. true story
Mine was Mrs. Orange.
great thread doug!!
thanks fellas!! really excited to own this, accept I got a feeling it's gonna be my biggest $40 moneypit I ever purchased LOL!!
can anyone help out regarding that throttle twist? I'd hate to spend $30 on a universal throttle temporarily then have to buy the oem parts I need as I like things to be stock, and I hate buying things twice!
Probably Fred /
> greg b Wrote:
> great thread doug!!
All you need is a throttle tube
> greg b Wrote:
> great thread doug!!
> guess a replacement throttle totals the ped then?
i checked, mine is magura controls, so i linked examples so you could see the odds and bobs involved, twist tube and grip are needed, as long as your cable and adjuster are ok.
thanks ken and glenn!! I think I found a youtube vid that shows whatever twist and lock method magura used
site success story right here! get her ripping!
