Re: Sachs Project Photo Album
wow.
I think I got it timed...not sure how good the condensor is. My spark detector light shows weak spark before I adjusted the points gap...
This things gonna be exciting to see the acceleration with the rear tire and gear!
#CrazyWayne #CrazyWayneRocks /
You need to replace those points when the cam follower gets worn out.
It throws off the mechanical geometry of the points opening.
Then the points are opening when the stator winding is not at maximum flux voltage.
And having an old weak condenser makes it even worse.
You should Gap your spark plug at 0.022" to 0.019"
The smaller plug gap will give the ark more time to burn due to firing at a lower KV voltage.
Chopped the frame. Installed a Batavus 16in rear wheel
Did you take that photo with an old Motorola razr, load it up in windows paint on MS '98, print it in black and white, color it with crayons, and then take a picture of that with your Razr before uploading it?
I didn't realize I had pics uoloaded.
might at well post some specs
16in Batavus rear wheel with 44 tooth.
magnum sprung shocks.
new treats gold chain
yes although the color is better
did you just come back to this build after a few years?
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
More pics plz!
been a while but it's still my current build.
I'm sorry but I don't have anymore pics just yet....gotta a D boltngo ready on the way tho. =D.............no pun intended
close up of the rear wheel. that sprocket is gonna be wild
got my bike running today.
It runs really well. the low end is remarkable. it only goes 20 but the accel is quick. one more thing I forgot to mention. my pipe is a Tomos Estoril sidebled but I have a secondary hole welded with a removable bolt and let me tell you that makes my low end very good.
gotta weld it up
diff angle
damn, that looks pretty gnarly, it's like at 1st you were doing a clean guy but I like the twist it's taken. 20 sucks tho, gear up and turn some torque into reasonable speeds!
I might get a Athena kit which will solve all my problems.
painted the bike white.
cool stuff guys
golden meadow
now I wait....
Josiah Radebaugh /
Lookin good. That seat looks comfy.
I shortened the downtube by 1inch.
although I altered the length I think I'll gain low end response I'm lacking.
Shorter pipe = more hi rpm
80cc Athena. Gonna match w 15mm Bing
Need an intake.
After year running. My bike cuts out to what i think is a failing condenser.
