Re: Sachs Project Photo Album
Okay nevermind. It runs great! Destroyed a 20 degree hill all the way up. Pipe really makes the grade. Carb cuts out at WOT starving for fuel. Gonna get a hose and clamp it to the carb
Heads up.
My magneto was slipping.
I fixed it by using valve grinding compound and blue loctite.
I put the compound on the shaft and kept twisting the magneto until the finish came through.
Ordered 85 jet. Im going this will make the bike more powerful and idle better.
Intake tube
Badabing!
Scooter? How r the squirls?
Switched to these super stiffy reed and purple coil overs.
I went for a fast romp about a half mile. On the way back everything was fine. I parked the bike like everything was fine i thought.
Then i tried starting it back up and the bike would turn over but the engine wouldn't engage.
So i pulled the cases apart and found this gear has separated from the shaft and freespins.
Oh Bubba no.
what! that's crazy. I got one if you want it just sittin in the basement.
I had the gear on the back of the clutch bell come free but never that main gear
Its ok tho i ordered a D bottom end....
Big update
Ordered an hpi internal rotor ignition!
Ordered 80cc Athena Reed valve piston port kit!
Porting powahhhhhhh
