Re: need help derestricting magnum x
Chris Straub /
Why make multiple posts about the same question? Roff pointed you in the right direction on your last post in /performance. Lose the stock pipe, the restriction is in the design itself, you want an expansion chamber. Weld one on the stock header or just replace with a whole new pipe. Lose the air box, add a high flow filter instead, upjet carb till one or 2 jets below 4 stroking at top speed. Stock intake should be fine with stock carb/cylinder. Stiffer clutch springs
