need help derestricting magnum x
Hey guys, I need some help derestricting my puch magnum x. I heard that if you derestrict the intake and exhaust it puts out 4.5 hp, how does one go about doing this.
Re: need help derestricting magnum x
Why make multiple posts about the same question? Roff pointed you in the right direction on your last post in /performance. Lose the stock pipe, the restriction is in the design itself, you want an expansion chamber. Weld one on the stock header or just replace with a whole new pipe. Lose the air box, add a high flow filter instead, upjet carb till one or 2 jets below 4 stroking at top speed. Stock intake should be fine with stock carb/cylinder. Stiffer clutch springs
yeah but I thought the intake was restricted on the bike.
No - it is because you made multiple posts
Sell it to me, I'll do it.
Take the pancake exhaust and throw it away, put a flipped circuit pipe on it and boom.
The intake is not restrictive. If its got the 17 bing still and intake then your steps ahead of performance add ons because those are great. MUST CHANGE PIPE! And atomizer in bing if ken didnt say already.
