Re: Honda Motocompo NCZ50 - The build log!
Cooper Liu /
Have mine mildly bored up, good compression out of the box; should get better as I break it in. It was about 100psi, now it is 130psi.
Since the kit didn't come with a new wrist pin needle bearing, I had to stuck with the stock one. But I realise there's ton of side to side play between rod and the piston since the new piston is 43mm. Is it normal? I dont want the bearing to blow up again in my cylinder..
  Honda Motocompo NCZ50 - The build log!Topic by: Toby B Toby B 08/24/17 08:30PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/24/17 09:40PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Overpriced Parts Overpriced Parts 08/27/17 12:23PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Responsible Jon Responsible Jon 08/24/17 09:42PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/24/17 09:56PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/24/17 11:06PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Stephen Keller Stephen Keller 08/24/17 10:40PM
  Re: Honda Motocompo NCZ50 - The build log!Re: jayson sumpter jayson sumpter 08/24/17 11:15PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Jonathan R Jonathan R 08/24/17 11:45PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/29/17 10:06PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Mike Boyd Mike Boyd 08/29/17 10:09PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/29/17 11:32PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Ryan Graeme Ryan Graeme 08/30/17 01:09AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Paul Boyer (OFMC) Paul Boyer (OFMC) 08/25/17 12:05PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Graham Motzing Graham Motzing 08/25/17 01:00PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/31/17 05:24AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Mike Boyd Mike Boyd 08/25/17 06:22PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Korean Fried Chicken Korean Fried Chicken 08/25/17 06:32PM
  Re: Honda Motocompo NCZ50 - The build log!Re: will warn will warn 08/25/17 09:48PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Dan (LandLordsMG/PSVMC) Dan (LandLordsMG/PSVMC) 08/26/17 02:22PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Dave Brzezicki Dave Brzezicki 08/27/17 07:29AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/28/17 12:51AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Wild Card Wild Card 08/27/17 08:19AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Born to be WillD Born to be WillD 08/28/17 10:06AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Tobias Doesn't Care (ง •̀_•́)ง Tobias Doesn't Care (ง •̀_•́)ง 08/28/17 12:16PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Born to be WillD Born to be WillD 08/30/17 09:50AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/31/17 12:22AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/29/17 11:36PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/31/17 09:25PM
  Re: Honda Motocompo NCZ50 - The build log!Re: will warn will warn 08/31/17 10:55PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Graham Motzing Graham Motzing 09/29/17 06:10PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/31/17 10:08PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Jawanna Blaist Jawanna Blaist 11/01/17 04:34PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Siezed Again Siezed Again 11/06/17 02:28PM
  Re: Honda Motocompo NCZ50 - The build log!Re: todd amundson todd amundson 12/17/17 05:56PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/31/17 11:08PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Dave & Bummerzz Dave & Bummerzz 09/06/17 10:29AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 09/06/17 06:45PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Kansas John Kansas John 08/31/17 11:50PM
  Re: Honda Motocompo NCZ50 - The build log!Re: buzzy mode buzzy mode 09/01/17 11:52AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Mike Boyd Mike Boyd 09/01/17 02:56PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Full Tuck Full Tuck 02/08/18 08:04AM
  Re: Honda Motocompo NCZ50 - The build log!Re: jayson sumpter jayson sumpter 09/01/17 08:46PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 09/04/17 01:36AM
  Re: Honda Motocompo NCZ50 - The build log!Re: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 09/04/17 04:18AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 09/04/17 08:46PM
  Re: Honda Motocompo NCZ50 - The build log!Re: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 09/04/17 08:50PM
  Re: Honda Motocompo NCZ50 - The build log!Re: will warn will warn 09/04/17 08:51PM
  Re: Honda Motocompo NCZ50 - The build log!Re: will warn will warn 09/04/17 09:00PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 09/04/17 09:05PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/06/17 10:08AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Nobody likes a bully. * Nobody likes a bully. * 09/06/17 10:46PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 09/06/17 11:25PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 09/12/17 08:22PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Huy Tran Huy Tran 09/12/17 09:31PM
  Re: Honda Motocompo NCZ50 - The build log!Re: buzzy mode buzzy mode 09/26/17 02:21PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/01/17 12:04AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 10/03/17 11:17PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 10/19/17 07:56PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Hepatitis J [OFMC] Hepatitis J [OFMC] 10/25/17 12:01PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Charlie BUZZARD Charlie BUZZARD 10/04/17 07:18PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 10/19/17 02:48AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 10/22/17 08:05PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Mike Boyd Mike Boyd 10/23/17 08:01PM
  Re: Honda Motocompo NCZ50 - The build log!Re: will warn will warn 10/22/17 09:19PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 10/22/17 10:16PM
  Re: Honda Motocompo NCZ50 - The build log!Re: will warn will warn 10/22/17 10:56PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Bas Autowas Bas Autowas 10/23/17 05:37AM
  Re: Honda Motocompo NCZ50 - The build log!Re: MPB Andyrew MPB Andyrew 10/23/17 10:21AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 10/23/17 05:38PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Mike Boyd Mike Boyd 10/23/17 02:09PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Glenn Kuehn Glenn Kuehn 10/24/17 04:47PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Dave & Bummerzz Dave & Bummerzz 12/18/17 10:17AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 01/08/18 05:15PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Cooper Liu Cooper Liu 01/15/18 07:56AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 01/15/18 04:56PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 02/04/18 11:37PM
  Re: Honda Motocompo NCZ50 - The build log!Re: David Cox David Cox 02/05/18 10:29AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 05/21/18 12:15AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Cooper Liu Cooper Liu 02/07/18 10:02PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 02/07/18 10:08PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Cooper Liu Cooper Liu 02/07/18 11:29PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 02/07/18 11:39PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 02/07/18 11:42PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 02/21/18 07:12PM
  Re: Honda Motocompo NCZ50 - The build log!Re: David Cox David Cox 02/21/18 07:26PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 02/22/18 09:52PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Cooper Liu Cooper Liu 03/18/18 12:42PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Derek Cox Derek Cox 05/20/18 08:07PM
  Re: Honda Motocompo NCZ50 - The build log!Re: David Cox David Cox 05/20/18 08:10PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 05/21/18 12:01AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Cooper Liu Cooper Liu 02/25/18 04:16AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 02/27/18 06:01PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/27/18 06:41PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 02/27/18 06:45PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Emil Kniemel Emil Kniemel 02/27/18 06:51PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Jeroen H Jeroen H 08/07/20 05:22AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/07/20 05:41AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Jeroen H Jeroen H 08/14/20 11:53AM
  Re: Honda Motocompo NCZ50 - The build log!Re: Ryan Graeme Ryan Graeme 08/08/20 03:42AM
  Re: Honda Motocompo NCZ50 - The build log!Re: max barsby max barsby 08/07/20 05:07PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Stephen Keller Stephen Keller 08/09/20 10:00PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Toby B Toby B 08/09/20 08:58PM
  Re: Honda Motocompo NCZ50 - The build log!Re: Stephen Keller Stephen Keller 08/09/20 10:03PM
